lots of questions |
gene41097
Newbie Joined: May-15-2007 Location: United States Status: Offline Points: 9 |
Posted: October-19-2007 at 11:02am |
I bought a 79 natique in the spring. Spent most of summer dealing with mechanical issues.now that seasons over,time to make her look a little better.The panels of glass under the windshield are missing the lock down screws and 1 guide. Where can I find these?I order an electronic distributor from skidim. Do you set the timing the same as the point type? Also, I read in a thread somewhere here,
that there was info on the site that I could take to a sign shop and they could make a stencil from that to paint the graphics.Where do I find that?That's just a start because I have a "boat load" of things I'd like to get done b4 spring.Thanks for any input. Sometimes being stupid and a newbie can make things harder than they really are. |
Gene41097
There's more to life than watching other people live it! |
Gene, The knobs are easy. Go here and enter part # 91185a374 in their search.knobs at mcmaster
The only problem is they only come in a quantity of 25! You may get lucky at a good hardware store. The slotted slide I feel will need to be made. You or a friend can cut and bend one out of aluminum. I ended up doing this for my 77. Small rubber bushings where the slide is mounted to the glass can be found at the hardware store. The stencil you are speaking about is a Gerbermask. You will need to find a sign shop that cuts vinyl and take a full size tracing to them. They will scan it and then cut the mask. On the timing question, you'll need to wait for someone else to comment. I'm not really sold on them and have never had a issue with points. Besides a possible improvement in starting, there isn't any performance gain. Good luck with your "boatload" of projects! |
gene41097
Pete,
Thanks for the info. the bolt and bushing that mounts the slide to the glass are intact, so it's just the slide i need. I'm in the process of wet sanding the hull. last night after about 2 hrs of this i thought ,I've rubbed on this boat more in the last 2 weeks than I have my wife for the last 15 yrs.maybe have priority issues?(lol) thanks again |
Gene41097
RainDog
Platinum Member Joined: February-21-2007 Location: Mke/Grn Lake WI Status: Offline Points: 1387 |
Good god man, we all just recovered from the last post that went down this road... The Goose |
