  New Posts New Posts RSS Feed - Heater Installation
Heater Installation
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCH20SKIER Quote  Post ReplyReply Direct Link To This Post Topic: Heater Installation
    Posted: November-18-2007 at 11:37am
I am considering installing a heater in my '96 Sport and looking for location guidance and routing of the hot air hoses. I certainly want to be able to have the observer to have the ability to relocate the place the heater hose where they want. Suggestions?
quinner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: November-18-2007 at 12:13pm
The factory typically installs the core/fan behind the driver kick panel, the windshield defroster outlet is center front of the dash pod and the other 2 outlets are in the kick panel, get the kick panel hoses that can be pulled out and moved about the front of the boat, mine will extend to the passenger seat. BTW, I never have needed/use my defroster, if you don't see a need I would skip that outlet.
bkhallpass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bkhallpass Quote  Post ReplyReply Direct Link To This Post Posted: November-18-2007 at 1:40pm
My aftermarket heater only has two ducts and does not include a duct for defrost. The pullout out hose is probably 6-8 feet long. Typically, I keep a blanket in the boat. several passengers can place a blanket over themselves, put the flex hose under the blanket and all stay warm. BKH
Livin' the Dream
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: November-18-2007 at 2:11pm
Brian,
Mine has the factory installed unit, only 2 duct outlets and a Y that splits the defroster and one of the kick panel outlets.
Post Options Post Options   Thanks (0) Thanks(0)   Quote behindpropeller Quote  Post ReplyReply Direct Link To This Post Posted: November-26-2007 at 5:22pm
I built mine using a couple of blowers and some heater cores. Less than $100 in it and it works great. I plumbed the exhaust water back into the line before the water strainer so the engine has some pre heated water to work with.
Tim
