  New Posts New Posts RSS Feed - Removing Windshield on 81 Ski
bk_broiler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bk_broiler Quote  Post ReplyReply Direct Link To This Post Topic: Removing Windshield on 81 Ski
    Posted: January-09-2008 at 11:25pm
Hello everyone!
I've had a great time just reading on the site and observing others' projects restoring their classic Correct Crafts. I am wondering though, how have people been removing the windshields on the 1981 Nautiques? I want to-do all the gel and repaint the dash (it is painted, correct?) and so I have tried to remove the windshield, frame and all. ALl I've been able to do is remove the glass. I've gotten out all the screws I could and I can't figure out how people do it.
Thanks!!
Brian
MaddMarxx View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MaddMarxx Quote  Post ReplyReply Direct Link To This Post Posted: January-10-2008 at 2:56am
Hey bk-broiler, whats cooking, the windshild comes off somewhat easy, just make sure you pull the two screws at corners that go in at an angle, you dont need to pull the glass out of the frame its not as heavey as it looks!
The dash on these boats was gel-coat, but you can paint it, just try to use a basecoat- clearcoat so it does not fade!
Post Options Post Options   Thanks (0) Thanks(0)   Quote bk_broiler Quote  Post ReplyReply Direct Link To This Post Posted: January-10-2008 at 3:37am
Thanks MaddMatxx!
those are the only two screws I think I didn't take out... they're a little stripped, so I will have to get new ones once I can manage to get them out.
Gelcoat? Even better, I'll just buff it down and restore it like the rest of the boat!
Thanks again!
jbear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbear Quote  Post ReplyReply Direct Link To This Post Posted: January-10-2008 at 3:58am
Your dash does look cool.
You gettin' the boat out much?
What is the progress on keith's boat?
john
"Loud pipes save lives"
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: January-10-2008 at 12:33pm
Good plan! It should come right back to life with a little bit of attention. Mine sure did.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bk_broiler Quote  Post ReplyReply Direct Link To This Post Posted: January-10-2008 at 9:17pm
TRBenj,
WOW! Your dash looks amazing! Is that just the gel restored?
Impressive, sir.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: January-11-2008 at 1:10pm
Thanks BK. Yep, the dash got the same wetsand and buff treatment as the rest of the top deck. I was very happy with the results- both the color and shine came back very nicely.
Barracuda View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Barracuda Quote  Post ReplyReply Direct Link To This Post Posted: January-11-2008 at 3:04pm
What, you couldn't buff that hole out?
Seriously, that dash looks great Tim.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: January-11-2008 at 3:26pm
I tried
I do have to fill that hole with something... I might have to put a stereo in eventually!
Post Options Post Options   Thanks (0) Thanks(0)   Quote bk_broiler Quote  Post ReplyReply Direct Link To This Post Posted: January-13-2008 at 2:54pm
Haven't been able to get the screws out... anyone have any tips? I don't think I can use a screw extractor, because of the angle... anyone else know? I can't even get a screwdriver in there well...
Post Options Post Options   Thanks (0) Thanks(0)   Quote bk_broiler Quote  Post ReplyReply Direct Link To This Post Posted: January-15-2008 at 2:14pm
*bump* Anyone have tips on getting these screws out? They're at a weird angle and are stipped... oy!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-15-2008 at 2:35pm
Dremel tool with a small cut-off blade?
Post Options Post Options   Thanks (0) Thanks(0)   Quote bk_broiler Quote  Post ReplyReply Direct Link To This Post Posted: January-15-2008 at 3:33pm
What, just cut off the screw head?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-15-2008 at 3:40pm
Yes and then put it back on with new fasteners. You mentioned that they were stripped anyway.
JoeinNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: January-15-2008 at 4:07pm
once you cut off the head and pull the windshield off you will hopefully be able to get some vise grips on there and get them out.
1983 Ski Nautique 2001
1967 Mustang 302 "Decoy"
Holeshot Video
Post Options Post Options   Thanks (0) Thanks(0)   Quote bk_broiler Quote  Post ReplyReply Direct Link To This Post Posted: January-16-2008 at 2:26am
What are the chances of success with using a drill to cut out the screw head? I don't have a dremel (yet, maybe on the wedding registry, I'm thankful to have a fiance who supports my boat love).
Thanks for all the help everyone!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-16-2008 at 7:18am
Brian, It's good to hear that you have the support with the boat habit from your fiance. I'm lucky to have a wife who loves the boats too!
The drill idea will work too as long as you can keep the hole centered on the old screw shank. Give it a try. I'm sure there will be plenty of screw left to get a vise grip on to get the old ones out like Joe mentioned. The deck under the winshield should be rather thick at that point. I've become a big fan of the little Dremel tool because it has saved me many times with all the little things they can do. At one time, I just thought of them as just a "hobbyist" tool. Not anymore! Do put one on your wedding registry! Congratulations-when's the big day?
Post Options Post Options   Thanks (0) Thanks(0)   Quote bk_broiler Quote  Post ReplyReply Direct Link To This Post Posted: January-16-2008 at 3:56pm
Paul,
I'm glad to have her. She's a wakeboarder like me, I just need to get her more comfortable with driving the boat (a PP would sure help :)) then all will be perfect. It's going to be hard to drill at the same angle as the screw shank, since the screw head seems to be facing down into the dash. I may be looking at the wrong screws, so when I get home, I'm going to check to make sure. :) These are the two screws on the INSIDE of the windshield at an angle?
Brian
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: January-16-2008 at 4:07pm
My guess is they are stainless and almost impossible to drill to begin with much less under these circumstances. Go to sears cough up 40 bucks and get a dremel.
Holeshot Video
Post Options Post Options   Thanks (0) Thanks(0)   Quote bk_broiler Quote  Post ReplyReply Direct Link To This Post Posted: January-16-2008 at 4:42pm
What head for the dremel should I be looking for then?
NAUTI84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NAUTI84 Quote  Post ReplyReply Direct Link To This Post Posted: January-16-2008 at 6:37pm
Brian
Hey, I'm going to try giving my wife the PP and see if that helps!
MM & Tim,
Great looking dash!
Brian,
Lets see some progress pics of yours.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bk_broiler Quote  Post ReplyReply Direct Link To This Post Posted: January-16-2008 at 6:47pm
Will do, once it warms up enough for me to do some more wetsanding :) Can't do it unless the temp is over about 25 (the space heater in the garage can raise the temp 10 degrees or so, and I need it over freezing).
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-16-2008 at 7:03pm
Brian, If you get the kit, it will come with a mandrel and a assortment of small cut-off wheels. If you just get the Dremel tool, you will need both. I really don't think the kits are that much more in fact by the time you buy the mandrel and wheels, it may be close to the same price.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bk_broiler Quote  Post ReplyReply Direct Link To This Post Posted: January-16-2008 at 9:52pm
Paul,
I don't think I found the screws you are talking about. THe ones I am thinking of are only about 1/4" long and they don't go into the hull at all. I've gotten out every other screw I can find on the windshield. Maybe mine is different? Where is the screw head visible on the ones you are thinking of? On the base of the windshield, inside, by the dash and in the corners? Or under the dash somewhere, through the fiberglass?
Sorry to be confused, i just can't figure this out!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-17-2008 at 8:38am
Brian, Sorry but I thought you found all the screws holding the windshield on to the deck! I've only mentioned how to get the ones that are stripped out and not the locations. The 1/4" screws you mentioned, are they holding frame components together? Are the threads or the heads stripped out? Ether way, at this point cutting the heads off is your only option. If it is the threads that are stripped, you will need to go to the next larger size screw say from a 8-32 to a 10-32. The same goes even if they are a self tapping sheet metal screw type. Keep posting, Pete
81nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: January-17-2008 at 11:05am
A few pictures would be helpful!!!! Maybe we could see what screws you're anguishing over but I would get a dremel and grind the heads off, end of story.
I'm assuming you pulled off the plastic cover that hides all the screws along the bottom and side rails?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: January-17-2008 at 11:47am
This thread is giving me a headache. It may be time for the BFH.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bk_broiler Quote  Post ReplyReply Direct Link To This Post Posted: January-17-2008 at 12:46pm
Sorry Hollywood :)
81, I think you answered my question. Noob mistake I'm sure, but I didn't remove the plastic. Makes a LOT more sense now :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: January-17-2008 at 1:04pm
Sorry Hollywood :)
That's where all your screws are hidden, under that strip. Save the BFH for the next headache
