  New Posts New Posts RSS Feed - Airguide speedometer lens
Sam B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam B Quote  Post ReplyReply Direct Link To This Post Topic: Airguide speedometer lens
    Posted: February-01-2008 at 11:41pm
Does anyone have a glass lens for a airguide speedometer that I can purchase? I hate to spend big dollars on a guage when I just need a lens.
Thanks Sam
anthonylizardi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote anthonylizardi Quote  Post ReplyReply Direct Link To This Post Posted: February-03-2008 at 4:03am
Sam,
    It all depends what type of speedometer you have. I have an SN 87 and the glass are removable. They are cracked so I need to replace them. Somebody suggest to replace them with a watch glass. Those are the crystal glasses you use on chemistry glass. I bought them online only for a few dollars. You will still need to buy a diamond drill bit to make the hole for the adjustment. I measure the old one and I was able to find the same size. Good luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote anthonylizardi Quote  Post ReplyReply Direct Link To This Post Posted: February-03-2008 at 4:06am
BTW, this is the place I bought them. They cost less than $2 each. Chemistry Watch Glass
Regards,
Anthony
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam B Quote  Post ReplyReply Direct Link To This Post Posted: February-03-2008 at 11:43am
Anthony,
Thank you I am going to order today look perfect.
Thanks again Sam
Post Options Post Options   Thanks (0) Thanks(0)   Quote anthonylizardi Quote  Post ReplyReply Direct Link To This Post Posted: February-03-2008 at 12:02pm
Sam,
   Glad to hear that will work for you. FYI, the diamond drill bit I bought is for my dremel. I guess you want the speed. I haven't done mine therefore I don't know how hard is to drill a hole on glass. It shouldn't be, I hope. That's why I bought four in case I screw up .
Good luck,
Anthony
