Exhaust Hose |
Big Pappa
Senior Member Joined: March-08-2006 Location: United States Status: Offline Points: 322 |
Posted: February-12-2008 at 5:38pm |
What is the best way to get the exhaust hose off of the exhaust manifold? I was trying to get mine off of my 85 2001 the other day and it would not budge. I know it probably has become attached from being on there for years, are there any tricks of the trade for getting it off?
TIA, Kris |
79nautique
if you are replacing it then cut it. Another trick is to use a phillips screw driver and run it around the manifold between the hose and manifold to break the seal but it's pretty tough stuff and doesn't flex much. A lot of the times its easier to remove the manifold and then pull it out of the hose.
SkiBum
Wrestle it back and forth until it gives. Not easy. Looks silly. But be careful about using anything to pry with because it may damage the manifolds.
79nautique
their cast iron so they won't break and if they do it's because they are rusted out and need replaced |
