Summerization check list |
jerry.nichols@m
Newbie Joined: November-05-2007 Location: United States Status: Offline Points: 10 |
Posted: March-13-2008 at 12:04pm |
I'm looking for a summerization and maintenance check list for my 99 Sport which has been winterized is currently in storage. Any ideas where I can find such a list?
Thank you. |
Jerry, Hopefully the boat has been winterized properly. Check that all the drain plugs are in place, then just hook up the battery (charged), check the oil and trans level then turn the key! It really isn't much but some of the marina's really push the "summerization". It must be a real money maker for them and I do know people who fall for the scam!
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Online Points: 21131 |
Pete, it may have been winterized with conventional antifreeze/coolant- which would need to be drained, rather than emptied into the lake or driveway.
Other than that, youre right- summerization doesnt really consist of much. It all depends on how it was winterized. |
Tim D
When was the impellor last changed?
Tim D
Tim, Is that why I have dead fish around the boat house the day after I get the boats going?? No, I switched to the RV years ago!!! Very good point though. |
it's a good idea to check the condition of the impellar, some leave it in all winter, check the belts, adjust as needed. Also it's a good time to check and adjust the rpm, timing, inspect the plug, rotor cap. Most will do a tune-up at the begining of the season and then they will change the oil and filter when it was winterized. It's not a bad Idea to replace the spark plugs also.
Barracuda
Jerry, Beyond what the others have stated above, there is winterization and recommissioning section in the 99 Sport/Air Nautique owners manual in the reference section of this site. Section 8.13 is where to start. Hope this helps. -Brad |
78nautique78
Groupie Joined: November-10-2007 Location: United States Status: Offline Points: 51 |
I'm so glad there's talk about SUMMER!!. Mike
Big Pappa
Senior Member Joined: March-08-2006 Location: United States Status: Offline Points: 322 |
Here is the list of things I do each spring to get the boat ready. All that I can think of though.
1. Pull the cover off and give it a good wash and wax. 2. Clean the interior. 3. 303 the Interior 4. Put the impeller back in. 5. Check, condition and tighten the belts 6. Check oil and transmission levels 7. Drain Antifreeze 8. Put charged battery back in 9. Run with fake a lake check for leaks and make sure everything is running good. 10. Clean and oil Teak Swim Deck 11. Check trailer bearings. 12. Check trailer and boat lights. |
shawnmc
Senior Member Joined: March-17-2007 Location: United States Status: Offline Points: 282 |
what is 303 the interior?
Big Pappa
It is a Vinyl Protectant. Here is a Link
jerry.nichols@m
Thank you all very much. One again, thanks to this forum, I am better informed to take proper care of my new (used) boat.
Here's to summer just around the corner! |
tullfooter
Grand Poobah Joined: March-02-2007 Location: White Lake, MI Status: Offline Points: 2225 |
Lucky number 13. Fill the cooler |
'85 BFN '90 BFN White Lake, Michigan |
Behl
Senior Member Joined: December-05-2006 Location: United States Status: Offline Points: 404 |
You might want to do your tune-up with new gas, not that left in tank over the winter
MaddMarxx
just buy a new Boat, its less work!
jbear
Better yet...use the boat year-round...right Mark?
john |
82wake2001
Senior Member Joined: February-14-2008 Location: United States Status: Offline Points: 240 |
Were is the impeller located on a pcm 351??
Sounds like you could really benefit from flipping through the engine manual, which is available on this site.
Joe where are you located?
82wake2001
79 I am in Akron ohio.....
oh well that is in ohio sorry, don't know what to say, but your doing pretty good on your own don't hire anything out and take your time like you have and you shoudl be fine, If you get in a bind stop/wait post your concerns then move forward. Always time to do it right, just don't always have to do it right now, some times it's better to wait and think about it before you create more work. But your doing a dandie job so if you come to a point you are scratching your head wait, ask questions then move forward you'll be happy in the long run.
Keith
Admin Group Owner / Operator of CorrectCraftFan.com Joined: October-20-2003 Location: Pepperell, MA Status: Offline Points: 1917 |
Yea, I replace the plugs along with the fuel filter/water seperator in the spring (oil, oil filter, tanny fluid are done during winterization). -Keith |
well I always liked to spray the cyl walls down with fogging oil in the spring before I started it and I would usually what to change the plugs untill some of the old gas and foggin oil burned off.
winniskier
Senior Member Joined: March-15-2008 Location: Gilford, NH Status: Offline Points: 193 |
I launched the boat for the first ime this year. It started right up. About 10 minutes later, it was overheating. Turns out the impellar failed. It was one season old, 18 months in the boat. Was this bad luck or should I have done something more? I guess I could look at the fresh water strainer at start-up to make sure its drawing water. Anything else?
Jim
I'd have to say that the impeller has been run dry without water or antifreeze from the winter lay up. |
winniskier
I guess the question then is how do make sure that it does not run dry in that situation. Should it be primed so it won't run dry on first start-up? Would using a fake-a-lake force water up to the impeller?
Jim
No need for priming, etc. By any chance, does your '97 have a shut off valve on the raw water pick up? My dad's '03 does. If that valve is shut, you'll overheat and fry the impeller pretty quick. Good call on checking the strainer for water flow at start up. Thats part of my routine every time I launch the boat. |
behindpropeller
If it failed when it was that old the most likely thing that happened is your O ring on your strainer dried over the winter and you were sucking air. Best thing to do at the beginning of the year is to pop the hose off of your raw water pickup and put it in a bucket and let it suck. If it doesn't suck then you have an air leak of bad impeller. Hooking the hose up can mask a problem. Tim |
moses
Newbie Joined: November-15-2007 Location: United States Status: Offline Points: 25 |
any of you guys out there got a source for leaf springs for my 76 ski tique trailer? they are 31 inches long and 1 3/4inches wide. i also found out if you don't have water to that impeller when you start up it will turn to toast in a few seconds. the fake alake works good. jlmoses
james m
Briman
Groupie Joined: July-12-2007 Location: United States Status: Offline Points: 68 |
I too am finally getting my boat out this week. The brutal floods we have had here in Iowa left all the lakes and rivers high for quite some time (I know know how you guys down south felt last year....we got all your missing water this year). I am wondering how hard is it to burn out all of the fogging oil? Is it ok to take the boat out once, then change the plugs afterwards, or am I headed for a letdown? I'd rather do it this way to burn out all of the stabil. I sprayed the fogging oil into the carb while running until the engine puked per someone on here. Or should I take the plugs out and clean them 1st? Sorry bout the hijack but I figured it's related. Thanks in advance, Brian
