  New Posts New Posts RSS Feed - 1968 Wiring
1968 Wiring
dag5303 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dag5303 Quote  Post ReplyReply Direct Link To This Post Topic: 1968 Wiring
    Posted: March-29-2008 at 9:30pm
What is the small silver 2 terminal box on the back of the tach? It is not wired to the tach appears to just be mounted to one of the tach studs. The original fuel gauge and oil pressure gauge hot wire comes through this box. The temp gauge which is newer replacement does not. I am putting in all new gauges and don't know if I can eliminate this part. No part# or mfg name.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-29-2008 at 9:35pm
David, Ohm meter it and see if there is resistance between the two terminals. I would have to say that it is a resistor for the old original gauges.
