no fuel to carb on 79 mustang with 228 merc (305) |
Author | ||
leroy5245
Newbie Joined: January-25-2010 Location: syracuse IN Status: Offline Points: 7 |
Posted: April-27-2010 at 12:56pm |
SO! after restoring the interior of my 79' mustang we placed the rebuilt 305 (rebuilt two years ago and not ran since) back in the boat and prepped. crank for some time and no fire. place a lil gas in the carb and fires right up.......so its a fuel prob. disconnect the fuel line from the fuel filter and give it a lil sucky sucky and no prob gasoline in my mouth! I'm thinking its the fuel pump but that seems peculiar seeing as how there wasnt any wear on it since it was rebuilt to years ago! Before I purchase a new one any seggestions? Look forward to hearing ya'lls insight!
leroy5245
one last thing.....after putting a bit of gas in carb we used starting fluid to try and prime the fuel line.....heres a video of it.
http://www.youtube.com/watch?v=rHenW7w-RFw |
emccallum
Platinum Member Joined: August-08-2006 Location: Clarks Hill SC Status: Offline Points: 1084 |
Is the fuel pump installed properly? Are you getting fuel up to the pump and not to the carb? Has fuel been sitting in the carb and lines for two years?
vondy
Platinum Member Joined: November-29-2007 Location: Dallas, Texas Status: Offline Points: 1116 |
Are the lines hooked up correctly? In and out.
GottaSki
Grand Poobah Joined: April-21-2005 Location: NE CT Status: Offline Points: 3333 |
Fuel pump pushrod there at all?
River Rat to Mole |
79nautique
It's a Chevy. It should have a lever arm perminately attached to the pump and not a push rod, sounds like they didn't catch the eccentric on the cam when the fuel pump was installed. |
emccallum
exactly what I meant. You need to turn the motor over as you install the pump. You cant just stick it in there. |
Luchog
what was stated above, or the pump diaphgram dried and cracked.
leroy5245
The motor has been sitting for 2 years but the last time it was started it ran perfect (I was there) and since then we have not replaced the fuel pump so it is installed correctly, I'm thinking it luchog is right and that over 2 years the fuel pump has just rotted out. Emcallum: yes there might have been fuel sitting for the past couple of years
Sounds like a case of bad gas. Id drain the whole fuel system and put some fresh stuff in before you buy any new parts. Bad gas smells like paint thinner... and it doesnt take long for it to go bad these days.
79nautique
disconnect the fuel line at the carb, turn over the motor, if gas shoots out it's not the pump.
snipe
Senior Member Joined: July-13-2009 Location: United States Status: Offline Points: 157 |
Had the sme problem this year. I put some gas in a clean soap dish bottle, squirted a LITTLE into the carb, and kept the motor running for a few minites. the pump then primed itself and I was good to go. Started every time. Good luck
horkn
It really sounds like you have gas that has gone bad.
I would disconnect the feed line that goes to the gas tank, and try running it in the driveway (water running to the motor of course) with an alternate gas tank of fresh new gas. If it runs then, you will want to drain as much old gas in the tank, and fill it with fresh gas. |
leroy5245
Well during the restoration I removed the gas tank and all the gas so it cant be bad gas. I did put a lil gas in it but I will try and keep it running longer by doing that. Thanks for all your help and I will let you know the verdict!
horkn
Any news Leroy?
Hopefully you are busy running the boat around the lake. |
