  New Posts New Posts RSS Feed - ’85 smoking at idle
’85 smoking at idle
Rich Olson View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rich Olson Quote  Post ReplyReply Direct Link To This Post Topic: ’85 smoking at idle
    Posted: July-05-2005 at 1:20pm
I have a 1985 with a 351
Smokes alot at idle, can't seem to stop it.
I put a new marine carb on a fwe years back, wondering if its jetted different? or something. Doesn't seem to be an adjustment for idle mixture.
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2005 at 1:26pm
Look down the carb when its running and see if its dripping...
River Rat to Mole
jameski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jameski Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2005 at 1:35pm
Black smoke is gas, blue smoke is oil. What color do you have?
current boat
94 Sport Nautique
previous boat
78 Martinique
Rich View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rich Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2005 at 2:00pm
I believe it is black smoke - boat doessn't burn any oil. I do end up with black residue on the back of the boat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jameski Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2005 at 2:10pm
What kind of carb did you put on it? I've never seen one that has no idle mixture adjustment. Some new carbs have the adjustment screws covered and sealed to prevent adjustment, but the seals can be removed when adjustments are necessary. How does the boat run? If the idle mixture is very rich, it will foul spark plugs and run rough.
current boat
94 Sport Nautique
previous boat
78 Martinique
