Shaft Packing |
Greg_SA
Senior Member Joined: April-19-2007 Location: South Africa Status: Offline Points: 168 |
Posted: April-14-2011 at 11:05am |
Hi,
I have read lots of threads here about the correct size packing for different Ski Nautiques, but I am still not sure what to use. Most 80's models seem to use 3/16" while most 90's use 1/4". My 1989 was just between the two. If I measure the inside diameter of the packing nut (where it is threaded), it is 37mm. The shaft diameter is 1" - 25.4mm. So, half of the difference is 5.8mm. So does that mean that I should use the 1/4" (6.35mm) or the 3/16" (4.76mm). I'm guessing the 1/4" is correct? It looks like 1/4" was in there previously, but it is quite squashed. It the packing meant to be very loose on the shaft until you tighten the nut? Or quite a tight fit from the start (before tightening)? Thanks, Greg |
1989 Ski Nautique (SN2001)
Chris4x4gill2
Senior Member Joined: August-25-2008 Location: Smith Lake, AL Status: Offline Points: 358 |
I used 3/16 on my '89
Greg_SA
Was it a tight fit, between the nut and shaft? |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21104 |
If you put 3/16" packing in a gland that needs 1/4", you will know it very quickly!
I would recommend you buy both if youre not comfortable measuring either the gland or old packing. |
Greg_SA
Thanks - I have both :) I'll try the 3/16" first...
Should the packing fit between the nut and shaft be quite tightly (snug)? Or should it be loose until the nut is tightened? |
Greg_SA
I was just looking at the packing nut assembly...
I measured the inside of the gland, when the nut is turned off, and the inside diameter is 26.3mm... so the clearance to the 1" shaft is very little! So there will only be around 0.5mm gap between the shaft and the packing gland. Is this normal? See the photo below. |
Nothing like some mixed units to confuse the issue.
Edit: brainfart... see below! |
Greg_SA
Thanks :) But is it normal that the inside of the glands is just a fraction bigger than the shaft? Shaft = 1", Narrowest part of gland = 1.035" Now, looking at the nut, if I measure the ID of the nut, I get 1.46" (see photo below). So isn't 1" + 2x(1/4" packing) = 1.5" not better? |
Sorry, brainfart. I forgot to note the extra zero... I was thinking 1.35".
You are absolutely correct- if the ID of the nut is 1.46 (green arrow), then you need 1/4" packing. No worries on the ID of the gland itself being 1.035" (red arrow above). The shaft does not touch it- it rides on the packing inside. |
Greg_SA
Excellent, thanks ;-)
I just thought the tolerance for the gland was a bit tight... I see that on the old shaft, it looks like it may have touched the gland - it is a bit polished. It is badly scored where the packing rope was (red arrow), and a bit polished further back (green arrow). See the photo below. |
Greg_SA
I just tried installing the 1/4" packing in the gland... I had the nut loose - put in the packing, and tried to push it over my old shaft, from the taper end.
It fits really tight - just the nut with packing (i.e. not tightened at all)! Is this correct? I can't just slide it onto the shaft, I have to work it on. How easily should the packing turn on the shaft? Thanks, Greg |
Greg_SA
With 1/4" I can only fit in 2 layers of packing.
So I just tried 3/16" and just packed it into the nut - it has some play on the shaft, but it I start tightening the packing nut a bit, it tightens on the shaft - so do yo guys think that 3/16" is probably correct? I can fit 3 or 4 layers. |
Greg,
Go for the 3/16". Put some time on the boat and keep a close eye on the gland while the packing conforms to the shaft. Don't let it get very hot. |
bfootr
Senior Member Joined: March-04-2019 Location: Benson, NC Status: Offline Points: 138 |
HI - I'm getting ready to pack the shaft of my 89 SN. Did you end up using the 3/16" or 1/4" size? Thanks.
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2822 |
It is likely that you need 3/16" packing. CC / Nautique did not go to the 1/4" packing until sometime after the year 2001 or 2002. JQ |
^^dangerous assumption right there. Have seen little consistency on packing sizes. Best to measure the gland or old packing, or order both sizes if unsure.
beardo73
Senior Member Joined: March-23-2018 Location: Slippery Rock Status: Offline Points: 123 |
If you have time, reach out to Skidim.com. I just bought packing for my rudder port assembly. I tried to order both 3/16" and 1/4". They called before they shipped stating that CC was only using 3/16" for these. Seemed to know exactly what they were talking about. Not sure of rudder packing would be same as drive shaft-- but might be worth a phone call?? My boat is an '88 Martinique for what it is worth. Good news is that this material is really cheap if you did need to experiment.
Good luck on search of info and assembly! |
1988 Correct Craft Martinique B/R, PCM 454, ~577 HRS.
The size may or may not be the same size hence the warning from Tim. Measure the prop shaft gland to be sure. |
SNobsessed
Get the Gore-tex grade, well worth the extra money!
oldskiboat
Groupie Joined: June-16-2006 Location: United States Status: Offline Points: 92 |
I didn't see this mentioned but when putting in the three layers be sure to stagger the butted ends so they do not line up.
