Convert PDF to HTML, image, Text, EPUB on Mac OS |
gordon33
Newbie Joined: May-16-2011 Status: Offline Points: 2 |
Posted: June-12-2011 at 11:51am |
Tanbee PDF Converter for Mac is the 5-in-1 PDF Converter for you to convert PDF to Word, PDF to TEXT, PDF to HTML, PDF to EPUB and PDF to image on Mac OS. After the conversion, you can easily enjoy or edit the files. You can easily choose the output format that you need Txt, Word, JPEG, PNG, BMP, EPUB, HTML format.
Featured with its user-friendly and easy-to-handle interface, the Tanbee PDF Converter for Mac makes you achieve any of the conversions with several clicks in few minutes. This PDF Converter is absolutely the standalone program, then you can directly use it with any assistant program like Adobe Acrobat or Adobe Reader and so on. * Convert PDF file to DOC/RTF/TXT text formats. * Convert PDF to JPEG/PNG/BMP image formats. * Support to choose the exact page(s) that you need. * Convert PDF Files in Batches. Tanbee PDF Converter for Mac Key Features Fast Speed - Convert Adobe PDF document into Word, Text , Image, Epub & HTML files quickly for mac users. High Efficiency - Support batch conversion and partial conversion. Batch conversion: import multiple PDF eBooks to the program and convert them at one time; Partial conversion: Customize the page ranges of each PDF eBooks in the panel for conversion, specify which page you want to convert PDF files. Good PDF conversion result - Preserves the original layout of text, columns, tables, graphics, images and hyperlinks after exported from PDF to Word, Image, Text, Epub and HTML. Intuitive interface and stand-alone programme - This PDF Converter for Mac is easy to use and has an intuitive and user-friendly interface. Meanwhile it is standalone--don't require Adobe Acrobat, Adobe Reader or other third party software to be installed. Easy to use - With its simple interface, Mac users can easily convert PDF to other formats as easy as 1-2-3. |
