help need battery isolation switch and bilge pump |
laurie
Groupie Joined: April-21-2011 Status: Offline Points: 44 |
Posted: March-17-2012 at 4:56pm |
Hi guys
got my new 2012 , 200 today The boat has red battery on/ off switch in foot well My boat is kept in the water. Do I turn the battery red switch this off every time I finished using the boat, and is my bilge pump still live? (the bilge states fully automatic on the label)Im afraid i turn off the battery switch and i have no bilge pump (the boat has no seperate ' bilge on' silver switch like the 206) Also i tried turning off battery switch filled area around bilge pump with water 2 inches but pump did not kick in? Is there a seperate float switch which may be in a dry area and therefore did not activate the bilge pump? confused?? the pumps seems to be wired directly to the battery help appreciated thanks guys |
laurie
baitkiller
OK, not 100% sure but > 90% sure you have whats called a "computerized bilge pump" Also know as a piece of shizat. Anyway, how it works is on resistance. There is a timer circuit in the pump that cycles the pump every four minutes or so. If the impeller has water and the pump senses that resistance it will continue to run until that resistance is gone/ Capice?
To see if it works at all find the fuse on the battery or switch, it will likely be brown with a tracer and the fuse should be within 7" of the battery or switch. Unplug, wait a minute and re-plug it in. The pump should run for like 10 seconds. There after it should run a few seconds every four minutes or so. The good is there are no floats to foul and one less wire connection. The bad is that they suck, are unreliable and suck batteries flat just for fun. Per ABYC that pump should be hot at all times. I'm betting Nautique has it wired through the Perko switch and it's dead with the switch off. Its a new boat, tell the dealer you want a proper bilge pump that you can trust the boat to with the batteries off and check manually when you feel the need. Like when you are taking on water! Hope I helped. |
laurie
Thanks
The pump works manually I undersdtand the red battery islolator switch turns everything off however the bilge pump is wired DIRECT to battery therefore i guess Nautique have wired the Manual wire instead of the Auto wire ( 3 wires, auto, manual and neg) to the battery i will check |
laurie
