Electrical Issues |
Author | |||
Jones
Senior Member Joined: September-07-2010 Location: Boise Status: Offline Points: 249 |
Posted: July-25-2012 at 4:26pm |
I was hoping for some advice on the steps I should take to troubleshoot some electrical issues I've been having lately. The symptoms are minor but they are bothering me. And, I don't have any experience using the new multimeter I bought so I would appreciate some elementary guidance.
1997 Ski Nautique, 5.8 carbed. New: Mallory Electronic Distributor and Coil (Discount Inboard Marine) Marine Alternator rebuilt starter Marine Starter relay Ignition switch Symptoms: Low voltage at the dash volt meter (never over 10V) Hot to the touch Alternator (but no burning electrical smell) 95% of the time the boat fires and starts with barely a click of the key. When it doesn't I turn the key all the way right and it cranks without firing like it's not getting any spark. The tach recently started getting jumpy and at idle and, when I know it's closer to 800, it reads 1000 rpm. I'm not sure if these are related or being affected by separate issues but the motor runs flawlessly otherwise. After running the boat for a few hours, I tested the battery voltage with the engine off and it read 13.17V Where should I start? Thanks in advance. |
1979 Ski Nautique (sold)
1997 Ski Nautique 1998 Super Sport Nautique |
Bri892001
Not sure about the alternator.
For the dash, you most likely just need to add a new positive and a new ground from the engine to the dash. On the ground side, you can tie all your grounds to a common bus. For the positive, you have to use a stack connector to go to the incoming side of your dash ignition breaker (if you have that) otherwise your key. The more connections that you can clean up, the better. Replacing runs of wire that look undersized or shoddy is even better. When I added the new positive going into my ignition breaker, that finally solved by low voltage gauge reading. |
Jones
Thanks Brian.
Jones
One down; I tested the battery with the key off an it showed 12.9V. Started the engine and took it to 2000RPM and it read 15.72V. I got the same reading at the alternator. It appears a bad alternator right out of the box.
Bri892001
So, was it pretty much all related to the alternator?
Jones
I doubt this would have any affect on the starting issue. Once I get the alternator replaced, I'll check to see if the ground is causing a low voltage reading on the dash meter.
pr0mjr
Newbie Joined: August-03-2012 Location: Mooresville,NC Status: Offline Points: 5 |
it doesn't sound like an alternator problem with > 14 volts while running. consider other options first.
BuffaloBFN
You're chasing a bad ground. Sounds like the alternator is fine. |
Don't rule out the hot feed to the dash ether! Both could be bad. |
BuffaloBFN
Yessir! |
SN2001fan
Newbie Joined: June-12-2008 Status: Offline Points: 26 |
could try a new harness too!
http://www.skidim.com/products.asp?dept=1155 |
Why? You suggest just throwing wiring in without testing? do you have a VOM? BTW, here's a correct link for the convenience of all |
Jones
I doubted the bad alternator so I had it tested and it was fine. After some research I discovered the PO never had the sense terminal wired. Ive never had an alternator with an onboard VR so I didn't know what to look for. Every things fine now with 14.24v while running and it's no longer running hot but my dash volt meter is still only showing 10v. I'll double check ground and + but it might be a bad gauge. The tack is no longer jumping. I wonder if the over voltage could have had an effect on this.
I doubt your voltage problem had an effect on the tach. keep in mind the tach simply gets' pulses from the point set opening and closing. Get the VOM out and check the volts under the dash. There are so many threads on undersized wiring and bad connections it confirms a common problem. |
Jones
Thanks, Pete. I'll start going through. I assume if I get less than 12v with the key on/engine off on any gauge, I've got a problem? I'd appreciate letting me know what to look for on the volt meter
Bri892001
Brad, if you run a new positive from your motor, from the protected side of the breaker, you should see some improvement on that dash voltage gauge.
There's really a lot of places to lose voltage before it gets to the gauge. It goes into the dash breaker, then over to the key, then through the purple (ignition switched positive) to the gauge. If you look at the (likely shoddy) wire ends as it junctions at all those different spots, you'll see how easy it is to lose voltage. |
gjsullivan
Newbie Joined: November-08-2004 Location: Hillsboro, OR Status: Offline Points: 13 |
Start checking for bad ground, bad connections an bad power.
I went though the entire harness on my 90 sport. Check your voltage from the battery through each connection to see where the voltage drop is. disconnect wires past where you are checking so you see voltage from the battery to that point. Check all terminal connectors, repair or replace any that need it. Put dialectric compound on every connection to prevent corrosion. I had a bad ground connector in the wiring harness block, had to cut it out rewire it, soldered it, and molded it back in. I wired a new +12 wire to the ignition terminal at the dash cleaned up all the connectors Ran a new ground wire from the engine block to a bus bar under the dash. and then had 6 different grounds from different areas wired to the bus bar. With all this my running voltage came up from about 10.5 to 13 volts. My gauges now read correctly. |
67 Mustang, 90 Sport
