keyless ignition |
rob200020
Newbie Joined: July-21-2012 Location: Northcarolina Status: Offline Points: 15 |
Posted: July-28-2012 at 1:15pm |
My 2000 PAN keyless ignition doesn't work. Tried reprogramming but no results. Any suggestions besides replacement @ $300?
rob
Bri892001
Smart pod? The last time this came up, the idea was tossed up of trying to "hot wire" it somehow. I guess that won't work.
Check out this thread: http://www.correctcraftfan.com/forum/forum_posts.asp?TID=26345 Although in this thread, it turned out to be a control box type of thing and not the actual keypad. But, people have had to replace those as well. |
IAughtNaut
Grand Poobah Joined: August-22-2010 Location: TN Status: Offline Points: 2568 |
once those keypads go bad there's nothing to do but replace them, I've been through a couple myself. the $300 hurts but as far as I know its the only solution.
IAughtNaut
what you should definitely do first is check your fuse box, when they pop out under those plastic covers its a real bltch to pop them back in. if that's what happened then you got off easy.
Dreaming
There was a keyless ignition in the for sale section a few days ago... used might get you by for a season or two, but it sounds as if they have a lifespan...
The lifespan of that bling sure would push me in the direction of installing a regular hard wired ignition switch.
wakeboardin2k4
Platinum Member Joined: December-14-2006 Location: Hopatcong, NJ Status: Offline Points: 1117 |
You said it big guy |
"I'm planning to bring my girl that rides on a trailer with me and leave my girl that complains about camping at home"
Bri892001
From what Joel said in the above thread, you'd basically have to completely re-wire the whole dash and ditch all the "smart" stuff on the smart pod to use a regular key. That keypad isn't like a regular key, it's sending a signal to the computer to turn everything on.
I never said it would be easy!! |
Bri892001
I think fo $300, I'd replace the key pad.
On the other had, if the computer aspect of it fails, that's over $1,000. I think at that point, I'd break out the wiring kit. |
Kristof
Grand Poobah Joined: October-08-2007 Location: Bree, Belgium Status: Offline Points: 3387 |
Aaaahh... The joy of electronics and bling in a wet environment...
My old girl already towed five boats this season with electronic issues... |
mdvalant
Grand Poobah Joined: May-06-2009 Location: Bellevue, IA Status: Offline Points: 2059 |
Sorry, late to the party. Most are right, you can't simply replace the keypad with the key. These boats run entirely off the PME (big black box under the dash by driver's feet). You would have to bypass that, which would then require you to re-wire lights, bilge, horn, blower, radio, ignition, and well...everything. You need to send your keypad to CC in Orlando and they will check it for you. I have their contact info if you'd like it you can email me and I'll help you get it down there. We sent our keypad down hoping it was the bad part....they tested and all was working perfectly. Turned out our PME was bad. It's one of two things, hope yours is the cheapest one
-Mike mdvalant AT Gmail dot com |
MTSkiNautique
Newbie Joined: January-04-2018 Location: MT Status: Offline Points: 1 |
I have a 2001 Ski Nautique and the accessory keypad (right side) quit working last summer. I want to have it checked before I order a new one in case it is actually the PME box. Especially since nautiqueparts.com will not accept returns or refunds on keypads. Do you still have the contact info for the place that tested yours? Thanks!
mdvalant
Talk to the guys at White Lake Marine I think we sent them our pad, if they're not it they'll know who to send it to. It was them or the Nautique factory...the longer I type this the more I think it was actually Nautique but you can try both. |
Orlando76
^^^ I can’t imagine Correct Craft factory getting involved.
