Transmission leak |
jlopez101
Newbie Joined: June-14-2010 Location: Seattle Status: Offline Points: 14 |
Posted: August-01-2012 at 9:27pm |
Hello CCF. I have an issue with my transmission. It's on a 81 Ski Tique. I've linked a picture here and I hope it works but basically fluid is coming out of the bolt shown in the picture. I've added fluid once before and it seems to be coming out at the rate of a couple teaspoons an hour.
Picasa Picture of Transmission Any help would be great. |
1981 Ski Tique
Julz,
The link didn't work for me, but try linking it again. If the leak is out the front end of the trans at the flywheel. then it's the front seal on the trans input shaft. That seal should not see any oil pressure so, if in fact it is leaking, you need a rebuild/ It's the pump internal of the trans that is the problem. |
jlopez101
Sorry about that. Give it another try.
1981 Ski Tique
kapla
I see the picture, looks like the fwd/reverse lever..thereĀ“s probably a seal there that can be replaced..
<a href="">1992 ski nautique
