knock sensor error? |
bbishop1974
Senior Member Joined: May-16-2010 Location: rindge,nh Status: Offline Points: 275 |
Posted: April-28-2013 at 1:23am |
Hello everyone,i have 2005 ski nautique 196 w/330 excal.At the end of last season the knock sensor see dealer message came up on the tachometer digital display.I assumed the knock sensor was bad and replaced it today.upon reinstalling the battery the message came back instantly.Any one deal with this issue? No check engine light and the boat runs great.Google search put me in some planet nautique forums but no real diag info there.Thanks,Brian
Foot_Fungus
Gold Member Joined: February-27-2012 Location: Chapin, SC Status: Offline Points: 501 |
If its a hard stored code you may have to have it erased/reset out of the pcm by the dealer. I think there is some crazy way to do it with a ton of engine starts that I saw over on PN.
I know that code will also pop if you have excessive timing retard(I thought maybe over 10 degrees, but I can't remember exactly), What kind of gas are you running? Might have some old/low octane gas in it that needs to be burned out. Other than that I'd check the wiring with a wiggle test, ensure you have it firmly snug and dont have anything like teflon tape on the threads, which can keep it from having a solid ground. If the message came back right away I'd think it just needs to be erased out of the pcm. Head to PN and see if you can find that reset sequence someone came up with. |
'94SN Restoration underway...
bbishop1974
Is there a way to clear the message warning without a scan tool?
bbishop1974
Thanks for the info,we posted at the same time.
