GT40 |
Post Reply | Page <12 |
AndrewB
Newbie Joined: August-12-2013 Location: Ohio Status: Offline Points: 35 |
Lewy I posted the garage info a few posts up. Things that make thr condition happen. Leaving the boat in overnight, running for 5-10 minutes come back down boat is not gunna fire unless wot. If im sitting with friends for a few hours wot ok first start. The odd thing like I said is if I pul the boat and put it back in the next morning first startup would not be an issue. Thanks for all the help you have been giving.
lewy2001
Andrew,
Leaving the boat in the water overnight is a real curve ball. What is different moisture under engine cover, colder, .......? Try the TPS removal and see what happens. I would also purchase the Eqqus Ford EEC1V Code reader it is inexpensive and may help if it has any stored error codes or sensor failures. |
AndrewB
Ok I'll have to order that. My thoughts were also the variables. Like how much water is in the coolant passages when I pull the boat. I really leaning far away from a fuel issue but the gas in the tank is another thing that is moved a lot, I know very unlikely but could it be a vapor issue. The vent in the tank seems clear as I blew into it. The whole pulling the boat deal is what throws me the most. I'd hate to take it somewhere because they will more then likely throw parts at it and cost me money. I can throw parts myself but at least I can return them.
AndrewB
Well no codes :( I did find today my primary coil measured in at 1ohm during the no start condition and range is .38-.42 ohms. Possible weak spark on startup then secondary takes over once running? I'm not sure how the ignition system works yet. Guess we will see what happens.
AndrewB
Well back again I've searched a few times and cannot find the info I'm looking for. Does anyone have wiring diagrams or a repair manual for the actual boat and not the engine. Vince from skidim advised me to check out my keypad and I'm not sure how it works but I'd like to test it.
Bri892001
Planet Nautique has a few later wiring diagrams that we don't have, but I haven't seen any real good knowledge on those keypads. Although, there has been a couple threads on them.
AndrewB
Thank you everyone for your help especially Lewy. Even though I never physically could catch my injectors acting up I replaced them anyways just out of a good suspicion after i drove the boat 15 feet shut it off came down a hour later and needed to wot to get it to fire. Seems faulty injectors were my culprit.
AndrewB
....blah
AndrewB
As of now I am pretty much shooting in the dark here and using this post to keep track of the zillion things I have done.
Condition: Boat fires right up pulling off the trailer. Drive short distance say 100 yards to the dock park the boat come back in about an hour sometimes boat will start and die others boat does not even fire it seems. After some extended cranking plugs are wet. After no start must WOT to get boat to fire then runs good until next long shutdown. I am currently throwing out the overnight cause because it does not seem to offer anything. Seems after first fire then shutdown is the real issue. Tested/Replaced: Fuel Pressue:40psi cranking Map Sensor Fuel Injectors IAC Valve ECT Sensor Ignition Coil Distributor Cap/Rotor Plugs and wires are around 1-2 years old with maybe low runtime.(Have a new set on the way) TFI Module ECM and F/P relays are only 1 year old. Have Injector Pulse while cranking. Have Spark while cranking. |
Bri892001
I remember you said you tested the coolant temp sensor, but how did you test it?
AndrewB
Replaced the ect but also measured resistance before and it was good. For the $10 the sensor costs
JoeinNY
Sounds like leaky injector(s) to me
AndrewB
I replaced the injectors
lewy2001
Andrew have you had a chance to try this yet? |
AndrewB
Lewy I have but I forgot to post the result and dont want to say what it did and did not do I will post back here soon with the results probably wont be out at the lake till this weekend but I want to say YES it did still start at WOT.
skfitz
Senior Member Joined: October-15-2009 Location: Herculaneum Status: Offline Points: 138 |
Sounds like your injunction pulsewidths are too large during hot cranking. Not sure how you'd confirm or fix that on a stock Ford system though.
AndrewB
Lewy the boat did start with the tps off and WOT. I discovered this weekend with the FPR hose off the boat fired no matter what. It was odd i fired the boat with the hose off then put the hose back on and it chugged like it would barely run until it finally smoothed out. There is no evidence of fuel in the hose but it did smell terrible of fuel. I am thinking the problem is in the fuel system here wether a pump or regulator I am not sure yet. I did apply vac to the regulator and it did hold.
lewy2001
Confirms that it is a over rich or flooded fuel issue. If it passed the fuel pressure leak down test and you have replaced the injectors that rules them out. It could be the fuel pressure regulator but that should have also shown up in the leak down test. It maybe somewhat intermittent causing false assumptions. Just because you replaced the ECM 12 months ago does not mean it can not have a new problem. But I hope that is not the case. |
AndrewB
Sorry I typed wrong I had replaced both relays on the back not the ecm. I am just so skeptical about it being an exam because of the way the problem arises. I'm going to try a regulator. I may take the boat to someone after this. The cheapest I found an ecm
for was 675. |
AndrewB
I really need to make a friend with a known good ecm to rule it out.
wetskier2000
Senior Member Joined: September-07-2005 Location: New Hampshire Status: Offline Points: 367 |
I see the first post says "solved" but I don't see the resolution in this thread..... What was the root cause? I have the same symptoms on a 1997 GT40. thanks
Current: 1997 Nautique
Previous: 1987 Nautique 1964 American Skier |
