351 Windsor Swap |
racingnc
Senior Member Joined: July-14-2010 Location: Mooresville NC Status: Offline Points: 170 |
Posted: March-07-2015 at 9:21am |
I have an odd question or not so odd. Is it possible to put an aluminum block from a newer mustang cobra into a boat in order to lighten the weight of the boat? The idea here is to get rid of the cast iron block. I know I would have to change all the internal parts to make it a right hand rotation motor. I am wondering if it would hurt the torque output and horse power?
Are you prepared to add fresh water cooling? There are some drawbacks to aluminum. |
halfnelly
Senior Member Joined: January-14-2013 Location: Maitland, FL Status: Offline Points: 253 |
A newer Mustang Cobra will have an aluminum 4.6 DOHC modular motor, which has never officially been marinized and probably wouldn't fit under any existing engine box because they are so wide. There weren't any aluminum block 351W in any production cars, they are only available through Ford Racing for bigtime $$$. A better option would be swapping to aluminum heads, but you'd probably want to look into a set with coated water jackets for marine use.
racingnc
What would you suggest for aluminum heads for a 1986 Ski Martinque?
Orlando76
What's a Ski Martinique?
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21122 |
Block material choice would have no effect on hp output, just weight and strength. Heads will change a little (aluminum dissipates heat better than cast iron so you can run a little higher compression ratio without detonation), but flow characteristics are really the primary determination of power output.
I would recommend taking a step back and determining your goals for the boat and establish a budget... We might be able to point you in the right direction. Why the concern with weight loss? |
ArtCozier
Platinum Member Joined: April-25-2012 Location: Orlando FL Status: Offline Points: 1023 |
The difference in weight won't probably won't make a measureable difference in the performance of your boat. All that hassle for maybe 1 mph??
"Art"
ArtCozier
Oh, and another important point that I just thought of..... There probably are no reverse-rotation parts available for aluminum blocks!
"Art"
