water leaking form my motor |
iliaskass
Newbie Joined: April-04-2015 Location: phoenix Status: Offline Points: 5 |
Posted: April-04-2015 at 1:25am |
water leaking between my tranny and motor plz help
JoeinNY
Could be pretty bad - cracked block from freeze damage. I would pop the transmission off and have a look. If there is no water in the oil and the engine is otherwise good then perhaps drain the engine and apply some job weld.
iliaskass
https://www.youtube.com/watch?v=6h5WJX0nLgE
So here is a link with a video i tool today. Let me know what you think. Also is it safe to take out like this. No water in the oil or trans fluid. Thanks so very much ilias |
CrazyCanuck
Senior Member Joined: July-21-2013 Location: Vancouver B.C. Status: Offline Points: 254 |
Could a frost plug have popped out part way?
https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcRtW3vJrMHLdqBzndt9VX3oOpBuRopGlzKq9Ea7pAO7wnTuoD8E8g
iliaskass
im not sure large round part that is between the motor and trans. i have no idea what purpose that part has. did you look at the video? its on my sec post
DrCC
Large round part = bellhousing
Personally I would not use the boat till you find where the water is coming from. (saw the vid) If you starve the exhaust hose from water you will then burn a hole, then sink to the bottom. Not boating is never fun, but it's a whole lot better than sinking. |
iliaskass
i hear that brother!! What would cause a crack in the that part?? motor mounts??
That's a pretty decent leak. I agree that you need to find out what's causing it before using the boat. Here's a direct link.
mamigacz
Groupie Joined: June-08-2014 Location: Wisconsin Status: Offline Points: 96 |
your engine is a 351W, right?
If so, there are no water freeze plugs in the back of the engine If its a chevy, there are two. |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21122 |
Are you sure? There are freeze plugs back there on a 302.
JDD33
Senior Member Joined: October-20-2012 Location: Natick, MA Status: Offline Points: 499 |
I just went out and looked at the 351W I have on the engine stand and it's the same as the first pic. That's a lot of water..... Need to pull the trans. |
Old school goin back to school!
LeftFieldEngineering
Senior Member Joined: December-20-2010 Location: Monson, MA Status: Offline Points: 384 |
My '79 Tique was leaking from the bellhousing. The 302 block was cracked on both sides, the left being worse, one poke with a screwdriver and the piece fell right out. I hope it turns out better then mine.
