Tranny fluid leakage "86 Martinique BR |
jblunceford
Groupie Joined: April-10-2015 Location: Hoover, AL Status: Offline Points: 89 |
Posted: June-22-2015 at 1:58am |
Hello all,
Hoping someone can offer advice on my boat issue. I have an '86 Martinique bowrider with the 351 PCM. Understand that it should have the BW 1:1 Velvet drive transmission. The boat is new to me this season. It's got just under 600 hrs on it, and is in really nice original condition (appears to have been well kept & maintained by PO). I installed a new ACME 540 prop and checked shaft alignment at the beginning of the season. I have run the boat 4 or 5 times so far, including this past weekend and I estimate I've put 5-7 hrs of total use time on it so far this year. I noticed some trans fluid floating in the bilge water the first few times out so I knew I had a tranny leak, but having previously owned an '84 Southwind with the same issue, I wasn't terribly concerned....just knew to keep an eye on the fluid level each time out. The trans was performing ok, possibly a little more noisy/rattly in rev than my prior Southwind, but otherwise ok. The 2nd time out or so, I noticed the trans had difficulty going into forward, but then check the fluid level, which was low, so I topped it off, the fluid level held up reasonably well, and everything went back to normal operation. This weekend I noticed that the trans fluid leak has gotten much worse. I learned this when the trans slipped after a 20-30 min cruise, even though I had topped off the fluid before heading out. I had a couple of families with me (and several children who wanted to tube ride), so I kept adding fluid to attempt to limp through the rest of the afternoon. Over the course of the next 2-3 hours and about 1 and a half hrs of actual running time (with several stop and starts changing out kids on the tube), I added about 1/4 quart of a partial bottle of trans fluid, and most of a full second quart to the trans, much of which ended up in the boat bilge making it look blood red under the engine. The performance and function of the trans is/was as follows: When the trans fluid level is full, the trans still seems to perform ok (?); it engages and pulls both forward and reverse. The trans got hot when the fluid level was low, as I observed smoke/steam from the fill port when removing the dip-stick to add fluid. The trans slipped 3-4 times that I recall, once at about 3K rpms in a tight turn (i.e., additional stress/strain on tranny when turning I suppose), and a couple of times when starting back up under load (forward) from neutral after 20-30 min runs. After the last slip, I noticed a whine in the trans at low rpm that seemed to go away (or get masked by engine noise) at higher rpms (25oo+). From the first time out, the trans has also made a whirring sound if I decelerated quickly from cruising speed, but I read in another post that that was the typical planetary gear (deceleration) sound that it common/characteristic of these BW trannies. Even though the trans still engages and pulls in both directions when fluid level is normal, I know the trans has gotten hot 3 or 4 times under my ownership. This along with the low rpm whine that started after the last low fluid level slip gives me the feeling that some degree of damage may have occurred (although possibly limited). I obviously have a seal(s) or hoses leaking either on/to/from the tranny or the fluid pump possibly (I understand that these BW's have pumps). I haven't been able to trace the actual leakage point yet, but hope to do so in the next few days. Other than tracing and IDing the leakage source, does anyone have recommendations for the next steps or things to look for? As far as I know, the tranny is original to the boat and never previously rebuilt. I'm thinking that a rebuild would be a reasonable idea if trans removal is required for seal replacement. I read a post on things to be aware of associated with rebuilds (i.e., thoughtful rebuild of ALL worn components including springs verses simply replacing parts, etc.), and would appreciate any references for good reputable shop(s)/or individuals to work with should a rebuild be needed. If I can isolate the leak to a hose or other part that can be R&R without trans removal, I'll continue to run the boat with trans as is and see if it will get me through the summer then re-eval at that time. Thanks in advance for any thoughts/suggestions/shop references that you guys may have. Jeff in Birmingham, Alabama 1986 Martinique Bowrider, 351 PCM |
Jeff in Hoover (Birmingham), AL
1986 CC Martinique Bow Rider 351PCM |
Jeff,
Since the trans has gotten hot which is a result of the slipping you are getting, I feel it's time for a rebuild. Don't tube!! |
GottaSki
Grand Poobah Joined: April-21-2005 Location: NE CT Status: Offline Points: 3333 |
Yank it out, get it to a reputaible builder and get back to summer without concern you can get back to the dock, because that is what;s next.
Some go to a bottle jack but i Smarly cut two 2x4 wedges to tap under the rear of the exhaust manifolds to support the engine with the rear mounts removed, which minus the trans is basically nuetral balanced because the mounts are in the middle of the engine unlike like the chevy. which has mounts more forward.. Buy a fresh dampner while it a apart, so you only have do this once every 30 years. |
River Rat to Mole |
jblunceford
Either of you guys know a "reputable rebuilder" individual or shop that you would recommend? I don't know of one in my area (central Alabama). I could possibly ship the unit to someone.
I'm not a mechanic by trade, although I've tinkered with some basic auto and boat mechanics over the years, and I am a detail oriented technical person by back ground. As such I appreciate and try to find similarly minded folks when I need mechanical work performed. If you anyone along these lines, feel free to offer up a recommendation...thanks |
BoyceByerly
Newbie Joined: May-19-2015 Location: Durham, NC Status: Offline Points: 17 |
Hey, Jeff, how's it going on this project?
I have a '79 Correct Craft Mustang, and I just noticed, after a day of tubing and skiing, that my bilge is full of transmission fluid. It had been leaking since I bought it, which is two years. A mechanic told me that it was a choice between adding fluid once in awhile, and doing a rebuild, so I just added the fluid and kept going. This, however, is a much larger amount of fluid than I've ever seen before, so I figure that strategy has come to an end and I need to do something serious. Can anybody recommend any videos/manuals/sources to help me on this one? I'm not afraid of getting grease under my knuckles, but this is the first time I've ever done anything more than add fluid to an inboard transmission. -boyce |
Boyce Byerly
Owner of a '79 Mustang |
jblunceford
Hello Boyce,
I've just sourced a local shop that I have confidence can do the rebuild for me...If I had better facilities, I would have removed the trans myself and sent it out to Fantastic Finish guys in Ohio, but the cost of paying for local removal and re-install, along with out of state shipping and rebuild costs, put the project total up near the cost of a brand new unit. As such, i'm dropping my boat off later this week at a local inboard-drive speacilty shop to handle the work. As far as "how to" instruction on doing the work your self, I ran across this on the Mastercraft teamtalk site.....it appears to be a fairly detailed documation of a guy's experience during his rebuild of a 1:1 velvet drive. There may be a better tutorial somewhere on CCF, but I haven't run across it yet. Good luck, Jeff http://www.mastercraft.com/teamtalk/showthread.php?t=53874 |
Boyce and Jeff,
I took a look at the link of the Mastercraft rocket scientist. If all you want to do is replace the clutch pac then it's fine but there's NOTHING about pump clearances!!!!! Excessive clearance of the pump is what you both need to be concerned about. It puts oil pressure at the front seal where it's not supposed to. That's where the oil is coming from. Jeff, Please report back to what your local shop has to say. |
jblunceford
I must have missed it....This is the first I've heard of a "pump clearance" issue. I was under the impression that the trans fluid leakage was age/seal deterioration-related.
So is it likely that I/we likely have a tranny pump problem? Is there some sort of spec or tolerance measurement that should be measured to determine a pump problem? If so, and the pump is out of spec/tolerance, does this merit a pump replacement during the trans clutch pack & seal rework? |
baitkiller
Pete I have to ask because I really don't know. Does the pump wear under normal use? Its just a gear pump riding in oil bath. Under normal use there is an oil barrier, cushion if you will between all the involved parts. Now the OP has a seal issue and has lost oil which can quite certainly damage a pump once that oil barrier is gone. Much like a big or small end bearing. My thoughts are that any damage would be pretty visible to the naked eye. scoring, bluing or what not. What say you? Could metal loss and clearance loss come about without any visual clues? My gear was rough as hell, full of salt water and froze up. I measured every thing in the pump and it was in spec. No signs of wear. I did, I will admit have a front seal leak/ I will also admit it was because I put the pressure relief spring washer on backwards.. OOps! All better now. Just curious what you have seen. I ask because I have seen engine oil pressure increase with new pumps even though anybody with a caliper could find nothing wrong with the old one. Same pump really.
my concerns with this rebuild is the shop not getting the friction plates flat and not stripping (both) pistons for cleaning. The reverse piston can hold a pound of crap and if just jamming forward plates in, will never be cleaned. We all know the kit is $140. Its the $560 in labor that needs to be properly directed. |
Jeff,
Even some seasoned very mechanically inclinded CCfan members won't mess with a trans. It's been mentioned several times that the best place to send it is FFM. There have been posts about so called expert trans shops screwing them up. I remember one that attempted to "rebuild" a Velvet twice. The trans was then sent to FFM. Sorry but they can be tricky. I hope your shop knows whats going on. No, I know of no published specs on pump clearances. All that knowledge comes from hydraulic gear pump basics. Eric the original FFM owner came from Paragon trans. |
John,
Any pump will wear with the hours. You may not see it with a visual inspection. Taking measurements on clearances is the key. The biggest enemy is water. That's the only thing that will produce the visual. Personally, I wouldn't touch a trans. It's just not work risking missing something and have the rebuild go south. |
