Tailer guide posts |
88skisupreme
Groupie Joined: September-13-2004 Location: United States Status: Offline Points: 50 |
Posted: May-25-2006 at 3:00pm |
what kind of metal should I use to add guide posts to my boat trailer? Also does anyone know what size pipe is usually used?
thanks |
duffnit
Senior Member Joined: October-12-2005 Location: United States Status: Offline Points: 235 |
Most trailers I've seen use 1&1/2" pipe. Some put a minimal bend (to the inside of the trailer) others are straight. Steel pipe works well and is easy to use. Once the guides are mounted use a piece of 2" (I think) plastic pipe (comes on a roll, found at most large hardware stores) to cover the pipe. Then just get a set of covered guide post covers. Usually fits snug on the 2" plastic pipe. Hope that helps. d
Danny
"no offense- but the rate at which you spread bad information is very impressive" |
I would like to add some guide posts to my trailer since the original owner had them removed. Would Home Depot carry a steel pipe that size? Who could bend it, a muffler shop perhaps?
79nautique
you can buy pre bent guide post from a trailer supply house.
duffnit
You can also go by your local weld and fab shop and get them to hook you up. Either way it should be fairly reasonable. d
Danny
