basketcase running gear |
75 Tique
Grand Poobah Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6103 |
Posted: June-21-2006 at 12:35pm |
Looking for any and all running gear from a wrecked or rotted boat inlcuding: rudder, shaft, prop, strut, shaft log, fittings, transmission, engine.
shum8
Newbie Joined: August-07-2004 Location: United States Status: Offline Points: 33 |
I have a tranny. Borg Warner Velvet Drive 1:1. Email me if interested.
boat dr
pcm 302long block,in my boat running good motor ,no smoke,no rattles,replacing w/331. also have an org.durbo-matic, good shape, replacing w/velvet drive. also strut w/ new bushing,and lots of other cc stuff.e mail me i need the bucks for the stroker........boat dr.
Barracuda
Moderator Group Joined: November-17-2003 Location: United States Status: Offline Points: 998 |
I've got a brandie new rudder port that fits a 1" rudder.
Also have a brand new prop shaft 1" x 41" Email me if you're interested. -Brad chillyh2o@charter.net |
eric lavine
what engine, what trans?
boat dr
PCM 302 w/755 hrs. just pulled the engine out of the boat. no problems had that need for more torque/horsepower. answer 331 stroker=my needs are met,now i need to sell parts and goodys i have gathered up. the tranny is a durbomatic,good shape also replaced it with the motor,do not know how much HP/Torque it will handle.answer; Borge Warner velvet drive will take $1000.00 for long block and tranny.long block is block, crank,rods,pistons, cam,cam chain,oil pump &drive shaft,no pickup tube and a set of recently rebuilt heads,what a deal........all you add is intake,carb,timing cover a dist. and an oil pan. call me if you have any questions........billy
