Drysuit seal repair |
Author | ||
fanofccfan
Platinum Member Joined: December-13-2009 Location: North Bend NE Status: Offline Points: 1720 |
Posted: February-20-2017 at 10:22am |
Does anyone have a good lead on where to get drysuit seals and if the process of replacement is easy enough to handle by myself? The last time I called Mike Sieple he was not in the repair business anymore. I sent two different suits to a place up north and they both came back still leaking water----- and the $150!
quinner
Have you tried OS Systems in Oregon??
fanofccfan
No not yet, but was just perusing their web site. I would sure like to get the same heavy duty seals so as to keep it "original" I will try iron Mike later today. He may have a place that does repairs by now. It used to be ocean tec in Florida but the last time I spoke with them they were no longer in the repair business.
HW is our resident drysuit seal repair expert, he'll chime in soon I'm sure. Believe he mentioned OS as referenced by Quinkles above as being the original manufacturer of many more recognizable companies (possibly including BI).
75 Tique
Grand Poobah Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6097 |
Pretty easy to do. I've done all four of my wrist and ankle seals. There are a zillion instructional videos on youtube that walk you through it. I am lucky enough to be able to get mine, specific to my brand of suit (BARE), off of amazon. Not sure how universal the seals are tho.
fanofccfan
Larry-Did you use contact adhesive or buy the glue from Bare? Just spoke with Mike seipel and they have not produced drysuits for about 4 years. Ocean Tec who produced them for B.I. now refers customers on to OS for the actual repairs. I will wait for HW to chime in and get the expert advice. Thanks |
quinner
So what am I, chopped liver, lmao. HW was who referred me to OS just last year, we will see if that has changed since then. |
fanofccfan
ooooops! good point! |
Valid point. Chopped liver may be generous though?
75 Tique
Available at any dive shop. Trickiest part is finding a form that is the exact size of the end of your sleeve or leg so that you have a tight fit to pull the new seal up on to. For the sleeve, I found a pickle jar that was just the right size. For the leg, I had an old round thermos bottle with a couple wraps of poster board around it. You want it to be snug, otherwise there is a chance of gaps between the new seal and the sleeve/leg, Eventually I will be doing my neck piece. I think they are a little more challenging. The videos usually appear to use a "custom made" form for the neck. |
Problem solved Larry
Morfoot
Grand Poobah Joined: February-06-2004 Location: South Lanier Status: Offline Points: 5311 |
joshjanae
Groupie Joined: October-11-2015 Location: Arizona Status: Offline Points: 87 |
+1 for DIY and use aquaseal. I've done it for dry tops and kayak suits and it is pretty straight forward. There are a bunch of tricks on youtube. I used a balloon on the inside. The hardest part might be finding the thick seals you want.
Hollywood
OS - The drysuit people since 1983. I'm still wearing shells from 1990 that are good as new.
There are plenty of urethane glues to choose from. |
fanofccfan
Thanks everyone (esp. Quinner aka: chopped liver). OS was the provider of choice and very helpful. Now while waiting for the seals to arrive I had better start eating some pickles! Thank goodness my neck seal is still functioning!
Morfoot
Just as long as it's you eating the pickles and not Connie!
skutsch
Grand Poobah Joined: June-19-2008 Location: Racine, WI Status: Offline Points: 2874 |
Per HW's directions, I changed out my seals using plain old Rubber cement and MEK - worked great. Only did wrist and ankle seals. Never attempted a neck seal, and I have one that needs it. Prior to "giving up" skiing, I had considered having one of these put in:
Quick Neck Seal - click on the video to see how it works. I think they also make these for the wrist and ankles. |
Donald80SN
Grand Poobah Joined: January-12-2009 Location: Denver, NC Status: Offline Points: 3887 |
Try Duct Tape, it works for everything else.
Donald Steve has no idea what Duct Tape even is- up there it's called Wisconsin Chrome
skutsch
So right you are Gary!
Donald80SN
Ah we call it 200 MPH tape for Nascar.
jbear
when I ask for the 200 MPH tape here at work cousin Don...the guys look at me like I am crazy..... john |
"Loud pipes save lives"
Thats because they are all damn yankee's John. Our neighbor from Cincinnati tells us yankee's are people from the north who visit,damn yankee's are the ones who have moved here...
nobrainsd
Senior Member Joined: August-13-2015 Location: San Diego Status: Offline Points: 157 |
I have repaired a number of drysuits. I used to purchase seals and glue from OS Systems. They are definitely good quality seals. But gluing is a hassle and the expensive glue goes hard in the can, which is a waste.
I have been using a dry adhesive that you apply with a heat gun and roller. It is so much easier to work with and the dry adhesive stores well. I purchased the dry adhesive and seals from Dive Right In Scuba. The seals are of good quality and the dry adhesive is great. Check it out! Dive Right In Scuba Dryseals |
rolleronariver
Senior Member Joined: May-24-2016 Location: Rogers, AR Status: Offline Points: 195 |
I noticed someone else mentioned aqua seal. We use that stuff on waders and it works very well. I had a brand new pair of neoprene waders a couple years ago that I ripped on a tree limb under water 4 days after I bought them. I used aqua seal to fix the leak and it still doesn't leak even 4 years later. Keep in mind, I duck hunt a lot and I go through some rough stuff and it has held up good!
92 Sport nautique
fanofccfan
No need for mass consumption of pickles. A 1.75 liter on Bacardi fits the leg and seal nicely. Also the attached handle works great for removing the item from leg of dry suit.
Used a yeti Coffe cup for the wrist seal of other suit. OS systems from Oregon was very helpful. Easy to follow instructions came with order and are also on the website. Hopefully they hold water out! |
