  New Posts New Posts RSS Feed - 1989 Ski Nautique 2001 system alarm
Allenk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allenk Quote  Post ReplyReply Direct Link To This Post Topic: 1989 Ski Nautique 2001 system alarm
    Posted: April-08-2017 at 5:52pm
My 1989 SN 2001 has some wiring issues under the dash. There were two orange wires, one hooked to the horn switch and the other not connected. Traced them out and found one coming from the horn( which turned out to be bad) and one coming from the alarm module. Replaced the horn and it now works off the switch. Attached the other orange wire to the system alarm. How can I test the alarm to see if it works. I think I have everything right according to the wiring diagram in the reference section.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-08-2017 at 6:08pm
Kevin,
I'd have to say the reason the alarm was disconnected is they don't work!! There's a couple threads on the alarms and one is a member who tried to rebuild/recreate the alarm. You can try hooking it back up but the common fix is to forget about it and watch your gauges which you should be doing anyway!
Welcome to CCfan. How about some pictures.
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: April-08-2017 at 8:23pm
Yes, alarm module is junk!
