  New Posts New Posts RSS Feed - Reverse Rotation Distributor Question
80tiquefan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 80tiquefan Quote  Post ReplyReply Direct Link To This Post Topic: Reverse Rotation Distributor Question
    Posted: June-13-2017 at 2:41am
If I have researched correctly, both standard & reverse distributors rotate in the same direction. The only difference is the pitch on the drive gear. I have a reverse rotation 351w and need to replace the dizzy & I have a new old stock standard rotation marine Prestolite distributor just setting around. My question is can I just swap the drive gear with a RR gear and it work in my RR engine?
Jason Murray
1980SkiNautique
1993 Sport Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-13-2017 at 8:16am
Jason,
Yes, just swap the gears. If both are Prestolite's, then the gear bores will be the same so no machining is needed.
Duane in Indy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: June-13-2017 at 9:38am
Jason,
Don't be too fast to say "yes" The distributors that I have worked on (gear swaps) are not always just a quick swap of gears. It appears that manufacturers don't have precision jigs to drill the cross holes in the shafts and gears. You may need to redrill the hole AFTER you make sure that the gear is on the shaft at the correct dimension from the mounting face of the dizzy'
Dimension from Ford Racing is :    4.031---4.038
That dimension is from the dizzy mounting face to the oil pump thrust face with the slack pulled OUT
Google: Ford Racing Distributor Installation   (pdf file)
        1978 Mustang (modified)
