transom light |
Lake555
Newbie Joined: July-29-2009 Location: Ohio Status: Offline Points: 34 |
Posted: June-14-2017 at 10:05am |
I noticed that this past weekend that our transom light on our 1991 SN was not working. Hopefully we just need a new bulb. I meant to bring the old bulb home with me to get a replacement, but left it at the lake. Can anyone tell me what size of bulb I need? Thanks
Dreaming
looks like there are a couple options for 91, as it appears to be a transition year. this is what NP lists though... stern light lamp
spiralhelix
Senior Member Joined: August-06-2014 Location: IL/WI Status: Offline Points: 496 |
if you figure out the size, superbrightleds.com can hook you up with an LED alternative. I replaced my entire dash and stern light. Not only will they last longer, they are cheaper as well.
-Spiral
'89 Sport Nautique |
Bri892001
Also make sure you're getting a good clean connection where the light attaches to the transom. Maybe put a litttle dialectic grease on the connectors.
MrMcD
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3587 |
My 95 is missing the stern light. Are they available?
I should have one in the boat for night trips. EDIT: Sorry Christines has them on the shelf. Google helped find it. |
Dreaming
Mark - I found mine under the observer side gunnel. its tucked way back up in there, but was clipped in, so I assume this is factory location. |
MrMcD
Dreaming, you saved me a purchase. It was right where you said, covered in dust probably been there since brand new but it was there. Thank You and Happy 4th of July!
Mark can you post a picture of it please? I suspect mine has been replaced with a different one---
MrMcD
Gary, I can do that but it may be a couple days, we are on the run this weekend.
Dreaming
Happy 4th to you as well :) glad I caught you before you ordered.! Gary, - NP has this one for 93-2000 boats, but this is not what my 94 looks like. https://www.nautiqueparts.com/product/stern-light-pole-all-nautiques-from-1993-2000/ Mine is this shape, but there are ribs in the light diffuser that seem more pronounced than the picture here... https://www.nautiqueparts.com/product/stern-light-pole-for-correct-craft-boats-1985-and-prior-using-base-5306076/ |
MrMcD
Gary, I am trying to post 4 pics that show my light. I don't know if it has ever been used, it does not look like it. There is a Oring on the plastic stop at the lower end. The oring is so old it fell off.
Thanks to you both. I think mine had been replaced by N3 with an Attwood brand when I bought the boat. I eventually found a Perko up front under the bow seating and that is the one that matches yours exactly Mark,thanks for the pic's. Now to find an o ring thats the right size....
FredWSauer
Senior Member Joined: August-28-2015 Location: St. Paul, MN Status: Offline Points: 156 |
My 93 transom light looks very similar. Most probably do. I have had continuous problem with the light bulb not working when it sits for weeks. If I pull the bulb out, and twist it in and out a few times it starts working. Next trip to lake I will try and grind a little sand paper onto the contacts.
- FWS
1993 Ski Nautique 1978 Glastron T-160 1994 Weeres Pontoon - Wife's Boat |
Dreaming
Fred - do you have a gob of dielectric grease in there? I imagine your light bulb and lamp contacts are getting corroded. the dielectric grease still alows the contacts to conduct electricity, but keeps the air/moisture out so that the contacts don't continue to corrode.
