Shaft and strut for Correct craft Martinique 1986 |
dan_b16
Newbie Joined: June-23-2017 Location: Quebec, Canada Status: Offline Points: 5 |
Posted: June-24-2017 at 12:02am |
Hi everybody! I'm new on the forum....!
i want replace Shaft, propeller and strut on my correct craft Martinique 1986. The old Shaft that i remove was 41" long, single taper with a 1"X4" coupler and the strut is a 6A-6.... when i look to ordered my new shaft and strut, the site recommand a 54" long shaft and a 6A-19 strut for my boat????? Somebody can tell me witch lenght of shaft and strut modèle it's suppose to fit on my boat? There is actually the wrong shaft lenght and strut on it?? Thank's |
Thanks(1)
Somethings up- here is the list I have 1973 and up Martinique shows a 50" shaft and a 154dv strut. What is the measurement from the rear coupling on the trans to back side of the strut?
Thanks(1)
Now that I look close at it though that sheet is dated 1980,they must have changed. That measurement I asked above will still help though
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21104 |
Thanks(1)
The 70-78 Martinique was on the ski nautique hull. From 80-84 it was the Bfn 19' hull. From 86-89 it was a larger 21' deep vee hull. Careful about sites claiming they know which years are which, lots of variation in that particular model.
6a6 and 41" shaft would be consistent with the dd Bfn (79-90), fwiw. |
Thanks(1)
There you go then,can't get an answer any better than that.
Duane in Indy
Thanks(1)
Is the existing shaft bent?? If not then it can be machined to accept a tapered coupling. Much cheaper alternative. I just finished a 41" shaft for a customer. |
1978 Mustang (modified) |
Dan,
Welcome to CCfan. Pictures of the boat would be great. Also, considering the confusion, double check the year of your Martinique. The HIN will be molded into the gel on the transom. |
dan_b16
Hi Gary
The mesurement from transmission coupler til back side of the 6A6 existing strut is 36". That's why i figure out the 54" shaft connot fit here....?? It's appear not the origin shaft and strut but it's fit...?? |
dan_b16
My HIN IS : CTC01121B686
Somebody know where can i verify my hin number ( web site, etc) the year on my certificats registration is 86 but.....?? Thank's everybody I gonna upload a couple of picture soon that i can....!! |
B686. Built in Feburary of 1986 as a 1986 model
dan_b16
Hi Gary
I check the list that you post and i see the martinique 21' long it's a 6A6 strut with a 1"X41" shaft..... so it's should mean that actual strut and shaft is the original size.... So if i understand my HIN, cause i see à old topic who talk about that.... CTC: correct craft 01121: serial number B : february 6: manufactured In 86 86: sale In 86 Thank's everything is better clear |
wiscofoot
Senior Member Joined: February-16-2018 Location: Neenah, Wi Status: Offline Points: 124 |
Can I assume that this strut model number is correct for my 1976 Martinique? It has a 50" shaft. |
1976 Martinique
