Water bonnet frame member |
swilliams
Senior Member Joined: June-26-2016 Location: Cincinnati,Ohio Status: Offline Points: 234 |
Posted: August-01-2017 at 6:40pm |
I am looking for the front windshield, port side outer glass frame member. It is on a 76' Martinique with the upper solid glass and the lower vent panels. This piece accepts the side triangular shaped assembly and also accepts the glass rubber channels for the front glass. PO must have damaged the upper corner. I would prefer the "mill" finish but would take a black one.Whew! I can't believe I did that all in one breath. I'd post a pic but every time I want to upload, it turns on my iPad camera. Thanks, Steve
1976 Martinique,350 Omc. 1975 Glastron/Carlson CV16,115 Merc.
ScottZ
Platinum Member Joined: January-20-2004 Location: Clanton, AL Status: Offline Points: 1143 |
The same thing happened to me when I tried that as well. I might have noe off of a South Wind that you could tweet it to work for you. I will check.
Lake Mitchell , AL 1984 Ski Nautique 1972 Skier |
swilliams
Thanks Scott
