Fuel filter / Water separator location |
JIMBOCC94
Newbie Joined: July-31-2017 Location: TITUSVILLE, FL Status: Offline Points: 4 |
Posted: August-07-2017 at 11:43am |
Looking for help locating where on my boat/engine the fuel filter and water separator are located.
The boat is a 1994 Ski Nautique 19 ft closed bow with PCM 351 Por Boss engine... Thanks... |
~~~~~~\o/~~~~~~~
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2840 |
My 1994 SNOB has the water/fuel separator mounted on the port side engine compartment, near the transmission.
JQ |
Dreaming
My 94 has the same location as JQ. Its an oil filter looking device, under the removable floor panel at the back of the boat. You may have to remove the dog house and floor to see it. the other type that came on the earlier models is black and orange, and has a replaceable filter element, if your's is different than mine is
JIMBOCC94
Thanks guys, I will investigate... i knew someone on here would know. I have a feeling owning this boat and being part of this group is going to be a great experience. Again, thanks for the help!
~~~~~~\o/~~~~~~~
gdenkman
Newbie Joined: November-07-2012 Location: Madisonville,LA Status: Offline Points: 38 |
Mine is port side, under the muffler, outboard of the transmission.
94 Ski Nautique
JIMBOCC94
Thank you gdenkman, after seeing your pics I now know the problem. It appears that a mechanic that worked on the boat previous to me removed the housing and filter and just put in a universal in-line filter. Probably because the filter/water sep elements aren't cheap... Dammit... now I'll have to have to find the housing to make it OEM...
Really appreciate the pic's |
~~~~~~\o/~~~~~~~
Dreaming
ski dim or Nautique parts should have both the filter and the housing
d_dumbauld
Newbie Joined: January-20-2020 Location: KS Status: Offline Points: 5 |
Hey guys - I'm set to replace my fuel / water separator in my '94 with the HO 351. I haven't had much luck finding step-by-step instructions. I was wondering if anyone knows / has seen one posted?
If not, I'd be happy to be the first to try to document. Thanks! |
zwoobah
Senior Member Joined: September-13-2018 Location: Providence RI Status: Offline Points: 308 |
Are you just changing the filter, or changing the entire housing?
The filter is just like an oil filter - spins on and off, check to make sure the old gasket isn't stuck to the housing. It'll be full of fuel when you take it off, so have a catch pan ready. |
1968 Mustang 16 - 351W powered
FYI, not all are spin on cartridges. The early canister style has an element inside so the outer housing needs to come off. There are several treads on how difficult removal can be. Some to the point where the whole separator is removed, placed in a vise and then use a large pipe wrench on it. |
d_dumbauld
Thanks zwoobah. That’s good to know. I took a crack at spinning it off back in the fall. It was stuck on good and tight and I couldn’t get my standard oil wrench in good position.. so I’m wondering if there a preferred filter wrench that makes it easier? Since it’s tucked back in there pretty good, I was wondering if it makes sense to remove completely the engine cover? Floor board? to make access easier. Or do folks have luck leaving that in place and using the right tool.
Thanks! |
David,
Is it a spin on or a canister? |
d_dumbauld
Looks like a spin on to me. But not 100%
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10637 |
Looks to me like it says "Spin on " on the side of the filter And the filter adapter is the spin on type too in your other picture |
d_dumbauld
Ha so it does!
Now you're 100% sure |
d_dumbauld
Yup! KENO - have you replaced the filter on this model before? Any tutorials you could point me to? thanks!
Pretty much just what Zwoobah said below. Same filter wrench that fits your Ford oil filter will fit the fuel filter. Because of the Anti Siphon valve on the tank only a little fuel will spill from the fuel line. A rag in the bilge under the filter should catch everything. If you can pre fill the filter most of the way before screwing it back on, it saves on the amount of cranking necessary to get the system full and the engine running again. And like an oil filter, put a little oil on the rubber gasket before installing and make sure the old gasket came off with the old filter. If the anti siphon valve is broken/non functional you'll have the tank trying to empty itself into the bilge. Right about then it's good to have a pair of vise grips handy to squeeze the line shut Or if you're worried squeeze it shut before removing the filter. Some boats have a shutoff valve in the line also. You don't exactly have a lot of room to work where yours is located
