Thermostat |
leftseat88
Senior Member Joined: July-06-2009 Location: Toledo Ohio Status: Offline Points: 106 |
Posted: September-26-2017 at 1:51pm |
Hey Everyone ,
Engine noivce here. I tried a paper gasket in the thermostat housing for the first time. I normally use RTV. I'm getting a couple of drips coming from the gasket area. Will this improve over time? Is this normal? The bolts are tight, the surface was cleaned before installation and the gasket went on straight. Thanks |
Did you ?
Regarding the T stat gasket leak, are the two surfaces flat? |
leftseat88
Pretty flat. I ran it around the lake and inspected it again, now no leaks.
