Engine ID- stumped |
Messer
Groupie Joined: May-28-2007 Location: United States Status: Offline Points: 63 |
Posted: October-05-2017 at 5:01pm |
This is not for my 87 Nautique, but I am stumped. My cousin has a boat with a 350 Chevy Mercruiser inboard. The number stamped just below the passenger side head is V0222DRX (Flint MI engine built on 22 Feb), but I can't figure out what the DRX stands for.
His/our issue is someone "repaired' the engine and now it's kaput. Since it is not a CC I lose sight of some of the standards that usually apply. So question- 1. Does anyone know what DRX stands for? Next, I am unsure of the rotation. Why, because the jackleg that "repaired" it may have changed the starter not knowing about counter rotation or standard in boats. So the typical "look at the rotation from the rear" doesn't work. From the stern the propeller indicates it is a LH or standard rotation, but the trans (Borg Warner, 10-17-006, 71C, 1.52:1), if I read right, mimics the engine rotation, but can easily be switched to counter the engine shaft rotation. Next question- 2. Does anyone know for sure if the 71c 10-17-006 can be manipulated to turn counter to the engine shaft or is it strictly a one way (goes the rotation of the engine shaft) trans? After that, how can you tell if it is LH or RH without knowing if the right starter is on it, and also not knowing if the trans is reversed? Are there any numbers on the engine block that I missed that will tell you. The manifold firing order is stamped as standard, but since the engine is rebuilt any manifold may have been placed on it. Thanks for any input guys! |
Johnnie
1987 Ski Nautique 1981 Fish Nautique 1980 Fish Nautique 1979 Fish Nautique 1986 Master Craft 1984 American Skier |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10606 |
An easy foolproof way is to take off the distributor cap and crank the engine over with the starter.
This is a Chevy you're dealing with so the distributor turns clockwise whether it's a reverse rotation engine or a normal rotation engine. Read the previous sentence 2 or 3 times to make sure you got that down If the rotor is going clockwise while you crank it, the engine is being turned the right way by the starter. If it's going counterclockwise you have the wrong rotation starter in it and it ain't ever gonna start. |
Messer
Dang Keno, your right... I knew that, but managed to completely overlook it. Thanks you sir! I truly appreciate it. ...In my defense, I am 50 now and ....well, ha
Johnnie
A 10-17-006 sounds like a Mastercraft powerslot. transmission.
I'd figure out if the engine is turning the right way before worrying about the transmission but a 10-17-006 will only turn the same way as the engine. |
