Heater Craft heater |
Post Reply | Page <12 |
Ken, Yes, I stand corrected and Mark is correct that the speed is controlled by resistance but, they aren't in the switch. They produce a fair amount of heat and the reason they are in the airstream of the blower. |
tjs1295
Groupie Joined: July-10-2015 Location: Wisconsin Status: Offline Points: 74 |
I just did the bypass test. Took a wire from positive terminal of the battery and touched all the switch terminals. Absolutely nothing happened. I am planning on cleaning up/redoing the ground connection next. Could that still be the reason it doesn't work? If it's more than just a switch or a wire I might just go without a heater. I thought if it was something easy or inexpensive I would like it fixed, but I'm not sure I want to buy a new unit if this one is shot.
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10649 |
It can't hurt to run a jumper from the bare spot on your ground connection straight to the negative battery terminal and then do the bypass test over again.
This way the power and ground are straight from the battery. Mark mentioned this earlier for the ground wire |
tjs1295
TA-DA!!!!!! That worked Ken (and Mark)!!!! The fan ran at all three speeds. So does this mean the ground is bad, or is that just a start of what's wrong?
Tom,
Sounds like Mark got it with the bad ground! Now just trace the original ground wire back and see where it's bad. |
tjs1295
Dumb question Pete, but what should I be looking for to see where it's bad? It looks pretty bad behind the dash where the ground from the volt gauge is spliced into it before they are both ground to the same terminal. I also did the breaker test like you mentioned. 11.85 volts at both terminals.
Tom,
I'd pull the wire connection off were it's connected at the volt meter. Take a close look at the connector and even pull on it. The crimp may be loose and corroded. If you have a new crimp on connector, I'd just put a new one on. Are there any other connections between the blower and volt meter? If so, check them too. |
tjs1295
Sounds good. There's some corrosion and almost fraying going on. I'll figure out how to redo that stuff. Then I'll check for other connections between there and the blower. I didn't see anything the other day when I was tracing it the first time, but will look again. I might not get to doing anything for a bit, but will update or ask more questions at some point. Thanks again for everyone's help. I learned a lot, so hopefully I won't ask such basic questions in the future.
Tom,
If you can't find the problem, my offer still stands come spring! |
tjs1295
Appreciate the offer Pete.
Well look at that, you got it figured out pretty much. Good job
You know the motor is good, you know a lot more about 12 volt electrical circuits and you have Pete's help in the spring if you need it |
tjs1295
Absolutely! Great learning experience. Wouldn't have happened if you guys didn't literally tell me every single step to take. But, at this point that's the only way I would have learned. I might be at the first or second grade level now instead of kindergarten.
tjs1295
OK, I know we all like to hear the follow up when people ask for, and are given advice. I finally got around to rewiring the corroded/cracked wires today. Pretty easy, got it all connected again, flipped the switch, and........ absolutely nothing!!! I started thinking that I would take Pete up on his offer to visit this Spring and help me out. But, then I remembered multiple people in this thread telling me to follow the wires thoroughly to see if there are other connections. So that's what I did next. Sure enough, buried behind the dash in the mess of wires was an inline fuse for the heater. The fuse was clearly blown. Put a new one in, flipped the switch, and the blower ran great at all three speeds. Thanks again for the lessons.
