93 SN - Replacement engine recommendations |
93 Ski Nautique
Groupie Joined: September-10-2004 Location: United States Status: Offline Points: 45 |
Posted: December-20-2017 at 11:55am |
Well, my 93 looks like it probably needs a new engine. The brackish water here near Annapolis, MD is tough on them and mine lasted longer than most. I pulled the heads as I had no compression in one cylinder and the machinist is telling me that there are more signs of water damage. I might be able to get away with new heads for a couple of years, but I may just do a long block to fully update the boat. Local conditions tend to mean the block will fail within a couple of years of the heads.
I see that Michigan Motorz comes up on the forums frequently. I will be looking for a 351 W, reverse rotation (my boat is one of the "base" boats from 1993). Any recommended suppliers? I am leaning towards Michigan Motorz or Jasper. |
M3Fan
Maybe hit up Jody Seal at Florida Inboards for a pull-out used GT40 EFI motor w/PP trans. Would be a huge upgrade and you could probably sell your old 1:1 trans. A handful of folks seem to re-power their 97-01 SNs every year in order to get Zero Off speed control which puts good used GT40s on the market.
MrMcD
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3582 |
How many hours are on this engine? I put heads on my old 1978 351W at 1000 hours due to one dead cylinder and it ran like new again till I sold it with 1600 hours.
Wipe your cylinders with fresh oil and a lint free towel and inspect them. |
93 Ski Nautique
Hmm, interesting concept. I will reach out to Joel, thank you!
93 Ski Nautique
Thanks for the reply. The motor has about 1300 hours on it. In this salt water environment it's more about corrosion than it is wear. I have found a set of heads and I may put it back together and see what happens.
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10606 |
You're mixing up your names that start with J Joel suggested checking with Jody at Florida Inboards, so get in touch with Jody |
Fl Inboards
Grand Poobah Joined: January-20-2008 Location: United States Status: Offline Points: 2061 |
Yes I do have a very nice GT-40 however it aint going to be an inexpensive endeavor! this GT engine has numerous new components including risers,manifolds,starter,alternator,raw and circ pumps. engine has less then 600 hours on it the only reason it has all this new components on it is cause i sold the used stuff here in the shop to low budget owners.
