Galvanic corrosion risk? |
MourningWood
Gold Member Joined: June-13-2014 Location: NorCal Status: Offline Points: 885 |
Posted: February-09-2018 at 1:27pm |
Getting motor ready for '81.
Using new aluminum heads and intake, other weight-saving measures. Question: Will I have an issue with galvanic corrosion that I need to address? Fresh-water use only. Thx |
1994 Ski Nautique "Riot"
FFImarine
Senior Member Joined: June-21-2016 Location: Medina Status: Offline Points: 142 |
you could use a quality zinc primer and then paint them if your worried about corrosion.
No
shierh
No real risk. If you are keeping it in the water and there are electrical faults with other boats in the marina then you would have potential risk. Most of the risk comes from shore power at the dock. Your safety ground could let in stray current from another boat that has electrical issues. Will eat your stuff up. We had wet boats for 15 years and we use to go through zincs every 90 days at some marinas. Problem solved once we put in a galvanic isolator.
Luchog
I'd be more worried for the different heating rates of having different metals on the engine while running an open cooling system.
For the galvanic current, you could use sacrifical anodes. Depending on the marinas and water you run your boat on, it can chew things pretty fast. |
