'88 Driver Seat Removal? |
Dank
Senior Member Joined: April-05-2005 Location: Austin, TX Status: Offline Points: 296 |
Posted: March-23-2018 at 10:50am |
I searched, but didn't find, so...
Should I be able to remove the driver seat by sliding the position adjustment all the way out? It stops in both directions, so I'm wondering if there is a "stop" that can be removed, or do I need to unscrew the base from the floor? Thanx in advance :) |
"I don't know what the world may need, but a V8 engine's a good start for me"
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21108 |
Pull up the seat bottom cushion- there are 4 nuts holding the seat down to the tracks. To remove the tracks from the pedestal, you need to unscrew the pedestal from the floor.
Dank
Thanx :) I'm actually wanting to replace the wood in the bottom cushion. The cushion lifts up from the front, but does not come off. It looks like I need to remove the staples from the back of the cushion (underneath) to pull it out and replace the wood. Does that sound right?
I would take the entire rotomolded seat out of the boat- doubt it will be easy/possible to pull the bottom staples off while in place. Otherwise that seems right.
