Identifying trailer type to replace bearings/seals |
mbshaw88
Senior Member Joined: April-28-2013 Location: Chicago Status: Offline Points: 244 |
Posted: May-08-2018 at 12:08pm |
I'd like to replace the seals and bearings in my trailer. 82SN with 6 lug trailer. Was really hoping to order the parts and do the swap without having to measure the spindle then wait for the parts to arrive. Can anyone confirm the bearing & seal numbers for this model?
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21102 |
Looks like a 86-87 Trailer.
There are 2 common options for the 5200/6000 lb axles available all over the web. The spindles are the same between the 2, the difference is the OD of the outer bearing, which makes it a hub dependent choice. Seals and inner bearings are the same between the 2. I have seen #3/4 cc trailers with both, the ones with a higher confidence of having the original hubs tended to use the smaller (5200lb) outer bearing but I doubt anyone can be 100% sure of what you’ve got until you take it apart. |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10604 |
Think global, buy local or something like that
Take one side apart and visit your local auto parts store and you'll probably walk out with what you need. |
Or you could order 2 new hub kits and be 100% sure you’ll get what you need ahead of time, and you can clean up the originals and use them as spares. It’ll also reduce the risk of a cracked hub stopping your progress half way through the job.
mbshaw88
Well if there's no way to be 100% I'll just take off one side and measure. It was worth a shot. thanks!
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2822 |
If you have a micrometer, you can pull one side and measure spindle, hub, bearings, etc. The bearings may have numbers stamped on them for identification. Good place to start.
Also, you can try www.etrailer.com and look under axle bearings. They have decent information and you may find what you are looking for. I like "National Bearing" or "Timken" brand. I recommend changing out races also when changing the bearings. I also like to use a bearing/race installation tool. My local O'Reilly auto parts store has them for "free" rentals. JQ |
mbshaw88
Follow up for anybody looking for this info in the future. My trailer:
#42 Spindle 25520 Inner race 25580 Inner bearing 15245 Outer Race 15123 Outer Bearing 22550 SKF Seal (Napa #27SS3177) |
throttle out
Senior Member Joined: May-11-2015 Location: Chelsea, MI Status: Offline Points: 153 |
Do I see a winch bolted to the trailer jack tube??
1989 Ski Nautique 2001 351 PCM w/ 1-1.23
mbshaw88
lol yeah it's a terrible idea and is only used a few times to drag the boat to the center of the trailer when its still in the water.
I finally got around to making a bolt-on steel mount that is almost done |
Matt,
The winch isn't a terrible idea but mounting it on the jack is. Winches will become very useful as more and more boat ramps ban power loading. The bolt on stand you are making should be made higher than the bow eye so the winch raises the bow of the boat as it pulls. This compensates for the trailer at a steeper angle than where the boat is on the ramp and will draw the boat tighter to the bow stop. Then, you need to use the original turnbuckle rather than the winch alone for trailering. |
mbshaw88
This should work a lot better
Matt,
Very nice job with the winch. |
Fabcon
Gold Member Joined: August-27-2012 Location: Buffalo. Mn Status: Offline Points: 552 |
1976 Ski Nautique 351 Escort
1984 Barefoot Nautique (Parting Out) |
