Bimini top |
Peacock
Groupie Joined: June-06-2016 Location: Carolinas Status: Offline Points: 47 |
Posted: May-23-2018 at 3:08pm |
My 1988 2001, came with what looks like a homemade sun blocker (Bimini top). I am looking for pictures of what an original bimini top looked like. Or did the 1988's not come with one?
If they didn't come with one, what do the rest of you do for a sun blocker? |
dgabler
Groupie Joined: June-12-2017 Location: Atascadero Status: Offline Points: 71 |
http://www.correctcraftfan.com/reference/bview.asp?id=55#image24 is a stock photo. will see if I can get you one tonight from mine.
dgabler
Thanks(1)
Here you go:
Dimensions Height : 29 Front-Back: 52 Width : forgot to measure The bimini was made by Adlee in Corona so they should have a template to go off of. |
gun-driver
Peacock
Welp, that shows me that mine is some kind of aftermarket junk. Now if you look at my boat you will see that the previous owner installed a ski tower. It does get used everyday when it's in the water.
I'm a thinking the proper top framing will not work with the ski tower. Whats your thoughts? It appears there never was a factory top, I see now hinge point mount nor clips for the straps. Also, where could I but the correct top and frame? Or is it more along the lines of, build one? |
desertskier
Platinum Member Joined: December-19-2006 Location: Az Status: Offline Points: 1114 |
Is there a reason that you have on backwards? |
dgabler
Actually I had not realized it was on backwards till you mentioned something. PO installed it that way, possibly to accommodate the big air pylon? Will have to flip it now I have removed the pylon.
NCH20SKIER
Grand Poobah Joined: December-16-2004 Location: United States Status: Offline Points: 2205 |
Backwards installs usually permit the Bimini to lay flat on the deck when not in use
'88 BFN |
desertskier
The Pylon theory makes sense.
fanofccfan
Platinum Member Joined: December-13-2009 Location: North Bend NE Status: Offline Points: 1721 |
That’s my reasoning as well. No,one else knows it’s bacerds unless they are on this site! |
s_kelley2000
Senior Member Joined: December-03-2012 Location: Boylston, MA Status: Offline Points: 141 |
Thanks(1)
How about mounting it to the tower? Obviously I have a different tower but you should be able to modify what I did to work for you if you want to go that route. Here is the link Let me know if you have questions.
1999 Python Super Sport
Timr71
Groupie Joined: March-28-2016 Location: Alabama Status: Offline Points: 80 |
Mine is also on the way it is in the picture. It lays forward of the windshield when I put the boot on. That allows it to stay on the boat when it's put away at the marina. And, that's the way the install directions from tower biminis says to put it on. You could still call it backwards if you like though. :) |
mark c
Gold Member Joined: May-09-2012 Location: Massachusetts Status: Offline Points: 534 |
Didn't even realize Biminis went back that far on the smaller boats. this is all I remember from back in the day.
More appropriately called a "convertible top" rather than a "bimini". Yes, pretty popular before the advent of the bimini. |
RichK
Newbie Joined: August-12-2011 Location: Los Angeles Status: Offline Points: 30 |
I think Adlee is gone, no? My 95 has an Adlee.
RichK
I think Adlee is no longer, correct? My 95 SNOB has an Adlee as well. |
I thought they were called Navy tops. I'll be disappointed if Ken does not know |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10643 |
Sometimes you just get disappointed Gary
Way back, we had a boat with one of those tops and it had zippered side windows and a back enclosure but I seem to think we called it the "top" Oh and I spent some time in the Navy too |
