Jabsco 17410 replacement |
CCCC1985
Newbie Joined: May-19-2018 Location: Ashland, VA Status: Offline Points: 6 |
Posted: May-23-2018 at 10:32pm |
Howdy, new member here from Richmond VA.
Just purchased a 1979 ski tique and after new fuel pump and filter, I found out the water pump is leaking from the back plate gasket. After looking at costs of rebuild with impeller and gaskets and who knows what else I may find when it’s all apart, I may take the easy route and replace it with the 18830. What I’d like to know is it a direct replacement part or will I need to modify the bracket? Any and all help is greatly appreciated! |
fanofccfan
Platinum Member Joined: December-13-2009 Location: North Bend NE Status: Offline Points: 1720 |
I replaced mine with a g21 Sherwood. Slight bracket modification but easily done.
CCCC1985
What does a slight bracket mod mean? Any reason you went with the Sherwood instead of the jabsco?
fanofccfan
I switched because a friend had a sherwood on a boat he no longer used and it was a quick temporary fix.......that turned permanent. If I remember correctly I had to drill new holes in the bracket for mounting the pump and I cut a slot in the bracket so I would not have to remove the sheave (pulley).
va-river-tique
Groupie Joined: February-01-2008 Location: Da Ville, Va Status: Offline Points: 63 |
Welcome to the site, it's a great place for knowledge. I'm in Mechanicsville with a 77 Tique that I'm finishing up a resto on so if you have any questions hit me up. My Tique came with the Sherwood pump. If you don't know the history of the impeller you may way to change that out to be safe and the kit should come with a new gasket and/or rubber ring seal which may be the issue with your pump.
I just changed the impeller on my Silver to find out that pieces of the previous impeller to the one I replaced were still jammed in the housing. Did you buy that while and blue Tique that I saw on craigslist recently? |
CCCC1985
You got it, va-river-tique. The boat was in incredible shape, other than needing said components. Garage kept and everything. The man who owned it used it to pull his grandkids on the tube at Lake Landor in Ladysmith.
I was pumped to find it because my grandfather had a 72 Martinique I helped him get back in the water, and this was pretty close to that boat. I am thinking of a full replacement w/ the 18830 due to several considerations. First being when I took the backplate off, I noticed that small fingernail-sized pieces of the plastic housing came off with the cardboard gasket. I was thinking of rehabbing this pump but after buying all the pieces, I will be close to the cost of the new replacement. I do have a question about the carb though. I have the commander 302 w/ Holley 4 bbl and it was rebuilt before I bought it, but not sure it was tuned. Do you know anyone who can tune up a carb for not a lot a cash? Thanks and ;let's grab a beer and talk boats soon! |
Cade, What are the problems you are having that you feel are carb related? |
CCCC1985
I am not sure I have problems yet, but when someone says they rebuilt the carb, I am taking it at face value not know the quality of their work. After I got the boat running yesterday afternoon, I didn't see where or how to adjust the floats and what not. The idle was a tad high and I adjusted that back down to 650.
I guess what I am looking for is a second set of more knowledgeable eyes to give the carb a once over to potentially remove any glaring issues before the maiden voyage. |
Cade,
Float level adjustments on your marine carb are internal. Get the boat out on the water and see how it runs. |
va-river-tique
I'm up for a beer and boat talk .... couple of good brew houses in the air park. sounds like you have a good handle on the carb. where do you boat at? We are either on the Chick at RIvers' Rest or Lake Gaston.
CCCC1985
Sounds like a plan to me, let's get together next week if you are around. Hopefully, the Tique will be purring like a cat by then.
I head to Lake Anna or Buggs Island on the other side of the dam of Gaston. My family has a place on Bluestone Creek, best skiing around. |
Just go to Harbor Freight and get yourself a vacuum gauge and connect it up to manifold vacuum. Adjust the idle mixture screws so you get the highest vacuum reading. You might have to tweek the float levels but thats pretty much it. Unless they really screwed up the rebuild..... |
