De-winterizing startup trouble |
Post Reply | Page <123 |
tryathlete
Platinum Member Joined: April-19-2013 Location: Lake Villa, IL Status: Offline Points: 1796 |
Where do you boat.? Lots of lakes near u!
shouse
Newbie Joined: July-16-2015 Location: Fort Worth TX Status: Offline Points: 35 |
Yup, quite a few 'lakes', even though they're all really just damned rivers. I boat on Eagle Mountain Lake, just north of Fort Worth. Our community has a private dock which is nice. I've brought it as far north as Clear Lake in Iowa to go to our family's lake cabin. I always seem to enjoy northern lakes more.
Smithfamily
Platinum Member Joined: December-26-2007 Location: Orlando, Fl Status: Offline Points: 1602 |
Well that was a good thread. Especially loved the part where Pete is installing speakers on a tower for the Atom. 6 volt. Great visual. That's funny.
And my original diagnosis was correct. I feel good. |
Js
Peter, I wouldn't worry about the rust on the flywheel and ring gear. How deep do you think the water got? If high enough, it may have rusted up the damper plate. Keep an ear open for sounds indicating the damper plate may be going out. Next layup, I do recommend removing the drain plug. |
tryathlete
My neighbor who has a Mastercraft has a bad cover and his starter got totally rusted but being a cheapskate (aren’t we all?), he just keeps using it even though it cranks slowly and takes a lot of juice to start.
Starters are pretty robust appliances. |
63 Skier
Grand Poobah Joined: October-06-2006 Location: Concord, NH Status: Offline Points: 4231 |
The boat really does look sharp!!!
Agreed, starters are tough. Fisher minute mount plows use basically a starter motor to run the hydraulics, and they endure pretty rough conditions with minimal maintenance. |
Grand Poobah Joined: June-06-2004 Location: United States Status: Online Points: 10640 |
Hi Jim and thanks for the reply I guess one maybe easy question is could someone walk into their local autp parts store (like Pete walking into his favorite AutoZone for example) and buy what you guys refer to as a true deep cycle battery or is a true deep cycle what is sold for solar installations etc. Is what's sold as a marine deep cycle a true deep cycle? It sounds like it's not. Otherwise it sounds like whatever you have for a battery, if you actually show it a little love and take care of it you should have far less problems than with the battery that sits neglected until you decide it's time to start the boat after a winter hibernation? And solenoid issues are gonna happen with whatever kind of battery you have if the battery is not in good shape? |
OptimaJim
Newbie Joined: April-01-2011 Location: Wisconsin Status: Offline Points: 12 |
KENO, chances are, if someone is buying a battery out of an auto parts store, it may be a dual-purpose, starting & deep-cycle battery, but it probably isn't a true deep-cycle battery. Those types of batteries can typically come in anything from 2V to 12V configurations, with 6V probably being the most-common. They will also tend to be significantly larger and heavier than most automotive-type batteries. Now, somewhere like West Marine may have true deep-cycle batteries, as well as dual-purpose batteries, because deep-cycle batteries tend to be more common in larger yachts. As with a lot of things, an ounce of battery maintenance can result in a pound of cure.
Jim McIlvaine eCare Manager, OPTIMA Batteries |
