speedometer |
Author | ||
Kat Daddy
Newbie Joined: June-19-2018 Location: Columbiana, Al Status: Offline Points: 35 |
Posted: June-22-2018 at 11:21pm |
My speedometer needles on my 88 need repainting, is the set screw std or metric? I cant seem to get them off, shld I use penetrating oil prior?
Trey, What set screw and what is "std."? |
The one in the lower middle of the clear plastic face that has nothing to do with being able to get at the needle. It's for adjusting the speedometers. You have to take it apart to get at the needle std is for American would be my guess |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21108 |
On many airguides in the late 80’s, there are larger (~3/8” diam) adjustment knobs that must be taken off to remove the lens, and the knobs are held in place by very small Allen head set screws. I do not recall the size offhand but it’s small and oddball for sure. Airguide was an American company so I’d bet on it not being metric.
A pic would probably help these guys calibrate their eyes if they’re not familiar with all eras of Airguides... I have some but can’t post easily from the phone. |
Kat Daddy
In the knob that adjust the speedo, there is a small set screw that im guessing needs to be loosened so the knob will come off to remove the faceplate. But its so small and rusted, not sure how else to take it apart and clean it
No need to guess. Tim explained that the knob does need to come off.
Have you tried to use any hex wrench sizes? |
Kat Daddy
He and i must have posted at the same time, i have tried a small allen, but must have been a size smaller than needed, i will go buy some, but didnt know if they were metric or standard.
I suspect the SHCS is a #4 or 5 so it would take a 3/32 hex key. The next size down would be a 5/64"
Kat Daddy
Thank you sir for yer help
I look at a pair of those newer ones on a daily basis and have to say "Tim you're right". Never have taken the newer ones apart, but the set screw in the side of the knob is teeny-tiny. A 1/16 allen wrench is way too big. |
