intake maniofld rust |
BaccoBouncer
Senior Member Joined: April-25-2016 Location: Essex MA Status: Offline Points: 272 |
Posted: July-21-2018 at 10:48am |
I pulled my throttle body and saw that I have significant rust on the inside of my intake manifold. A concern?
I really just want o get my carb conversion done and not have this grow into a larger project. I am a bit concerned about this going south with an intake manifold bolt breaking or something and the whole thing spiraling into a loss of the full summer. But of course I don't want to be crushing rust into my valve seats either if that is what is happening and I end up with a head rebuild in a season or two. Regards, Adam |
'97 21' Sport Nautique
BaccoBouncer
If i do swap intake manifolds to an aluminum one does it have to be a marine intake manifold for a fresh water boat or is automotive ok?
Thanks, Adam |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10649 |
Automotive is OK You never know, you might have rust in the intake ports to the cylinders and under the valve seats already,and if you take the manifold off at least you'll be able to check |
BaccoBouncer
Yeah I think I'll pull it and swap.
What's the best source for one? PCM GM 5.7L Thanks, Adam |
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2842 |
