  New Posts New Posts RSS Feed - planetary problem
planetary problem
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Topic: planetary problem
    Posted: August-22-2006 at 9:56am
this is definitely a maintanace issue, just tore down a borgski, planetary blown apart, case wore at the 12:00 position, transmission not rebuildable. CAN NOT STRESS ENOUGH HOW IMPORTANT ENGINE ALIGNMENT IS, DONT USE THE LOOKS GOOD METHOD EITHER,also dont cheat with a band aid prop saver, please open the manual and follow directions, or ask on these forums
alignment is critical, critical, critical!!!!!!!
