Low pressure fuel pump GT40 |
man0seven
Senior Member Joined: September-16-2018 Location: Utah Status: Offline Points: 122 |
Posted: October-27-2018 at 3:44am |
Hey all, I have been searching for the low pressure or electrical fuel pump for the GT40 EFI. I saw the ones on Nautique parts and skidim but couldn’t believe that it was 200. So I found these:
Carter P4389 In-Line Electric Fuel Pump https://www.amazon.com/dp/B000CSWR9W/ref=cm_sw_r_cp_api_i_fI.0BbDTGFVY1 And https://www.summitracing.com/parts/crt-p4389?seid=srese1&cm_mmc=pla-google-_-shopping-_-srese1-_-carter&gclid=EAIaIQobChMIipSR1_Sl3gIV1rjACh1mMwmpEAQYAiABEgJa-_D_BwE Are not these the same? I couldn’t find some cross reference for them. Thanks Brian |
2005 Ski Nautique
Brian,
From Gary's post last year, it looks like you found the correct pump.
MrMcD
Carter made the factory pump and the replacement Carter will work perfectly for you. You might need to change the connections on your wires but that is a minor adjustment.
