Best way to clean engine parts at home? |
robdubbleu
Senior Member Joined: December-26-2016 Location: Mt. Island Lake Status: Offline Points: 120 |
Posted: November-28-2018 at 5:08pm |
Hey folks,
I'm taking apart basically the whole engine to rebuild. I need to clean all the metal pieces that aren't going to the engine shop, such as pulleys, thermostat housing, etc. What's the best way to clean off all the old paint, rust, grease, etc? I know elbow-grease will be needed, but what do you guys recommend as the easiest way to go about this? I'm not in a hurry at the moment so if there's something I can soak them in for a week or so, that'd be great. Thanks! |
1976 Ski Nautique (PCM 351) - Currently under major renovation: floor, carpet, interior, gel coat, engine overhaul - ALMOST DONE!
baitkiller
I use diesel fuel.
SNobsessed
Lamp oil (you can get it at Wally's) is basically a hi grade kerosene & works well for me.
If you have baked-on grease, oven cleaner works good too. |
MrMcD
Thanks(1)
Since the cost of solvent went up I have been using diesel fuel. It is cheap and available and many gas stations. It is not flammable making it pretty safe for this use.
It breaks down grease quickly. For minor jobs I use a product called purple power. It works well for cleaning dirty engine parts. For internal engine parts and the engine block internals I use Dawn Dish wash soap and warm water. Then dry and oil the parts quickly so they don't rust. For the Tin, Oil Pan, Valve covers, Timing cover I drop them off at a local machine shop. He runs them through the hot tank. There is sludge under the windage trays in some oil pans and valve covers that you can't get to. The sludge drys out after the engine is apart for a few weeks as you overhaul and wait for parts. When new oil is introduced to these sludge deposits they break up and can do damage to a new engine. If your valve covers and oil pan do not have windage trays or areas that can't be cleaned just wash them out.. |
baitkiller
Mark I use the purple stuff when parts come out of the diesel. I just use a tin oil change pan and a real parts brush. Spay, sit and power wash. Then a spritz of CRC and onto the cart.
