Raw water cooling flow diagram |
Mogens
Newbie Joined: November-02-2018 Location: Denmark Status: Offline Points: 12 |
Posted: November-29-2018 at 2:59am |
Hi
I have a 71-72 ish correct craft conqueror crusader 302 with 220HK On the exhaust manifold there is a gasket just before the end piece where the exhaust hose is mounted. there is a stainless center in this gasket, this plate closes for water flow is it correct? Is there a good overview of water flow in a drawing or manual. ? My engine is with raw water cooling. |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10606 |
Hi Mogens Page 32 of the manual in the link has a block diagram of the cooling water flow for raw water cooling on a Conqueror Crusader Ford from that time period It's not exactly the simplest cooling system out there link |
Mogens, Could you post some pictures of the exhaust manifolds, the elbow (where the hose connects) and the gasket between the two. They would give us a better idea of what you have exactly. There is a possibility they have been changed/retro fitted at some point. |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21104 |
I agree, post a pic of the manifolds and that gasket. Several of us have conqueror crusaders and are familiar with the cooling system.
Mogens
Hi
Here is a photo of the 302 still in the hull. Its out now and in loose parts. |
Mogens
I have 2 solid gaskets
Its either from the from or rear. I did not see this before separating the part, if its in the front or back I cant tell. Or it's a wrong gasket . |
I’m familiar with the manifolds and the cooling... I want to see these gaskets you’re talking about.
Mogens
Hi
Here is the 2 gaskets |
I do not recall splitting mine, but I would block the bottom. The 3-hole gasket should go on the front plate and the 1-hole should go between the manifold and riser.
Is that crusader blue? Pm me if you want decals. |
