Vr1 20 50 on sale, cheap! |
Post Reply | Page <1 345 |
Author | ||
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21108 |
Post the links, so much learning needed.
rosconole
Gold Member Joined: May-10-2008 Location: United States Status: Offline Points: 758 |
I think you should stick to the prop encyclopedia
1989 ski nautique ,1991 barefoot nautique, 1993 Mustang Cobra 1998 5.0 Magazine shootout invitee
Duane in Indy
1000 hp? I am assuming that was per cylinder. At least that is what our motor made. Actually more like 1250 per hole.
I'll let you and Pete haggle this one out.. |
1978 Mustang (modified) |
Air cooled VW's and Porsche's always specified straight weights back in the day too. The average person didn't realize in addition to air cooling they were also oil cooled. The word back then was under extreme heat that the multi weight would break down back to it's base weight. Our Farmall tractor,if it got too cold out it would refuse to start with 10-30. Straight 10 it was fine. Oil has come a long way in 40 years, back a few years ago when I was crazy enough to put up with cold weather I found out that 10-30 was now ok. Today I don't care- it was 89
Duane, Thanks for the link but I do have the manual. |
Duane in Indy
Gary, The old 36 hp VW barely had enough oil anyway. Did not have to worry about orange filters cause they did not have a place to put it
Duane in Indy
Pete, You are welcome, but the link was not intended for your use. I knew that you already were knowledgeable on the engine. |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10643 |
Roscoe , you're racking up those bonus points for "entertainment value"
But Ross, a Wisconsin engine isn't made by PCM!! FYI, Wisconsin does recommend multi weight oils per the manual. |
I know what you mean Duane. When you only have 36 you need to know every one's name. Here is the Mrs back in the 90's with her '55 Oval- |
Orlando76
Those Nazi Road Oilers leaked so much oil you didn’t need a filter. |
You should have had a British car then,even the shocks have filler plugs because they leak so bad.
rosconole
Was it over when the Germans bombed pearl harbor...
Duane in Indy
You must have had a different History book than I did. |
NCH20SKIER
Grand Poobah Joined: December-16-2004 Location: United States Status: Offline Points: 2205 |
Well if you want to quote famous movie lines...... Bandit: the fact that you are a sherif is not germain to situation Buford T Justice: The GD Germans had nothing to do with it you sumbit&h |
'88 BFN |
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2840 |
As quoted by "Bluto" Blutarski (John Belushi) in Animal House... |
Orlando76
Roads? Where we’re going we don’t need roads.
75 Tique
Grand Poobah Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6097 |
Surely, Duane got the Pearl Harbor reference ( I hope)
"And don't call me Shirley!" |
