How much carpet? |
bfootr
Senior Member Joined: March-04-2019 Location: Benson, NC Status: Offline Points: 138 |
Posted: March-29-2019 at 10:22am |
Hi, searched the forum and didn't see an answer to these questions. How much replacement carpet (length) is needed for an 89 SN 2001? Getting ready to replace mine and planning to go with the 20 ounce weight. Also, is it best to buy 6' or 8 1/2' width? Lastly, is there a source for the plastic carpet trim? Thanks!
6’ and 2.5x boat length to account for floor, walls and all the panels.
man0seven
Senior Member Joined: September-16-2018 Location: Utah Status: Offline Points: 122 |
I just did some carpet on mine('98 SN) but only did the sides and some of under the bow. So the sides, the engine cover base, observer seat, and all the panels, we used 25 lineal feet at 8' wide. It was barely enough.
2005 Ski Nautique
rosconole
Gold Member Joined: May-10-2008 Location: United States Status: Offline Points: 758 |
30 ' was what I heard gets it done on 8'
1989 ski nautique ,1991 barefoot nautique, 1993 Mustang Cobra 1998 5.0 Magazine shootout invitee
gt40KS
8' is for NWZ and newer since their beam is wider - his 89 only has an 84" beam so 6' carpet should work, as TRBenj said. This confirmed by Christine's when I was called them about mine last year.. They said to be comfortable I'd need the 8' width, but if I had one of the older models from the 70's or 80's the 6' works although it wouldn't allow for a whole lot of waste.
Those guys were so helpful. Too bad they aren't around any more. |
JCCI
1995 Ski Nautique GT40 |
I did my NWZ with 6’ wide. Not a lot of extra width, but it reached.
gt40KS
Yeah, that's what Christine's had told me as well. More experienced or profesional installers would get the 6' a lot of the time. But since this was my first and the original carpet was a mess - not reliable for a pattern - he advised to get the 8' and I'm glad I did. |
JCCI
Mojo
Grand Poobah Joined: December-06-2006 Location: United States Status: Offline Points: 3104 |
Tim, You found the old bi- color , 70's style carpet once. What supply house was that from again? |
05' SV211 TE
There were a lot least a half dozen places that carried the black/red and blue/blue AstroTurf/grass carpet. I’ve found salt/pepper as well. Can’t remember the sources I’ve used, but I found them with the google. No dice on the orange/black nor blue/black (that I’ve found).
Mojo
How about Black and Brown? I did find one and it was complete junk when it showed up... |
05' SV211 TE
Can’t speak to the other colors, though I’ve seen some tans available (and lots of green, lol).
Riley
Grand Poobah Joined: January-19-2004 Location: Portland, ME Status: Offline Points: 7946 |
Quality of the fake turf really varies. We had samples for the red/black stuff from 3 places and they were all different. We had to buy a whole roll to get the best quality that we found. We should have some for sale if anyone's looking for red/black with marine backing.
I'd like to find the source for the salt/pepper. |
FLCaptain
Groupie Joined: February-10-2019 Location: Orlando Status: Offline Points: 45 |
Thanks(1)
You don't need the trim. Get 2 times the length of the interior. By 6 feet from Lowe’s. Pull out your floor board behind the motor box. Cut and 1/8th inch off each side. Glue the carpenter and wrap the edges. Then cut the hole for the stuffing box and that’s done.
Lay the maid floor to the edges. Then cut the last long sheet and do the sides to the floor. No trim needed. Use the Lowe’s glue or Marine glue |
bfootr
Nearly finished with the carpet replacement. Ended up buying 35’ of 6’ width carpet which worked out perfectly with little to spare.
One question, thinking about eliminating the access hole/cover over the shaft and packing nut to give the floor a more finished appearance especially since the center floor board is removable anyway. Any reason that this would be a bad idea? |
JoeinNY
Thanks(1)
I have never actually used the access plate for it's intended purpose, if you don't like it there send it packing... |
bfootr
Also, in replacing the carpet, I noticed that the exhaust tube was wrapped in carpet and affixed with zip ties. I would assume to further quiet the exhaust. Does anyone know if this was done from the factory or not? Thinking about NOT replacing it either as long as it’s not too loud. May sound better also?
75 Tique
Grand Poobah Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6097 |
Thanks(1)
I do believe it was that way from factory. Dont think it was done related to sound, tho that could be part of it, think it was done to keep the tubes from rattling around against the hull and stringers. For that reason probably good idea to leave in place or replace.
JoeinNY
Thanks(1)
I suspect, rattling and rubbing would have been the concern - you do not want to wear a hole in the bottom of your mufflers. If you do not want to reuse the carpet method, consider some rubber strips to insure little relative motion between possibly abrasive surfaces. |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10646 |
Thanks(1)
It was a money saving move at the factory, hide some scrap carpet in the boat or throw it in the trash and pay to get it taken away
Like Larry and Joe said it kept the tubes from rattling against the hull, especially the copper tubes in the pre muffler days. |
gt40KS
Thanks(1)
I left my access plate installed. Well actually I bought a new one since the original was trashy looking. Unlike NY Joe, I use mine every time I put in just to reassure myself there's no surprises. And because the removable floor panel doesn't come out without taking the back seats and doghouse out first.
.y boat didn't have anything wrapped around the 4" soft wall for protection when I pulled it for the rebuild. But when I reinstalled everything I uses some of the old exhaust tubing split down the middle and zip tied to the new as the buffer - Worked out great |
JCCI
babybooey
Newbie Joined: May-01-2018 Location: Toronto Status: Offline Points: 15 |
Is there any specific type of carpet which would be recommended for wrapping the pipes. Any concerns with heat and a crappy carpet or certain type of carpet backing?
Nope. Whatever you have laying around.
Back in the days, CC was notorious for using this. |
babybooey
Any recommendations on placement of carpet. Below is how i got it.
