RR 351w Build |
Apex
Newbie Joined: November-28-2018 Location: Indiana Status: Offline Points: 10 |
Thanks(1)
Posted: May-01-2019 at 8:39am |
I'm building a reverse rotation 351w for a Ski Nautique 2001 and thought I'd share some of the details. I'm building the engine a little over stock
Parts list to date, as follows: Part Part # Price *CYLINDER HEADS: PBM-Erson aluminum cylinder heads F1752062 $ 950.00 *PUSH ROD GUIDE PLATES: ISKY push rod guide plates 7005 (200AGP) $ 88.00 *PUSH RODS: Erson custom length push rods 1908-8 $ 120.00 *ROCKER ARMS: Erson S/S aluminum rocker arms 1.6 ratio 106-16, YBL-302360R $ 229.41 *CAMSHAFT & LIFTERS: CAM Research water ski cam kit CR112016 $ 285.00 *CAM BREAK IN SERVICE BY CAM RESEARCH $ 60.00 *HEAD BOLTS: ARP 154-3603 $ 99.22 *OIL PUMP: Melling M-83 $ 43.55 *TIMING CHAIN SET: PBM Performance Products 702, 73004-3 $ 38.19 *PISTONS: Sealed Power H336CP $ 192.98 *PISTON RINGS: Hastings 2M 139 030 $ 36.49 *ROD BEARINGS: King CR814SI $ 29.84 *MAIN BEARINGS: King MB5505SI $ 37.99 *CAM BEARINGS: Dura Bond 510S $ 24.68 *OIL PAN GASKET: Fel-Pro marine 1pc 17998 $ 54.86 *FRONT SEAL: Fel-Pro marine reverse rotation 17795 $ 21.44 *FRONT COVER SET: Fel-Pro marine 17875 $ 18.56 *HEAD GASKET SET: Fel-Pro marine 17260 $ 151.72 *BRASS PLUG KIT $ 12.50 *REAR MAIN SEAL: PCM marine 1pc reverse rotation R047041A $ 81.58 *EXTREME ZINC ASSEMBLY LUBE $ 6.00 *SHIPPING CAM RESEARCH $ 38.00 *INTAKE MANIFOLD: Weind Stealth WND-8023WND $ 247.95 *PERMATEX ULTRA BLACK $ 8.29 TOTAL PARTS $ 2,876.25 MACHINE SHOP EXPENSES *BORE AND HONE .030 OVER $ 175.00 *CLEAN $ 100.00 *R&R CAM BEARINGS AND PLUGS $ 75.00 *CLEAN AND POLISH CRANK $ 65.00 *PRESS OFF AND HANG NEW PISTONS $ 75.00 TOTAL MACHINE SHOP EXPENSE $ 490.00 |
MrMcD
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3592 |
Nice build should be a good runner.
Personally I trust either the Clevite or Federal-Mogul/Sealed Power for bearings. Dura Bond are very good for cam bearings but for rod and mains both Clevite and FM compete for the OEM business and I put my eggs in that bucket. It is a key part in your engine. Everything revolves around those bearings. King has been around a long time, made in Israel and they are a lower priced part but I prefer FM or Clevite for peace of mind and for the technology they offer. |
kjhoover62
Newbie Joined: July-01-2022 Location: Houston Status: Offline Points: 1 |
What are the specs on the Cam Research (Part #CR112016) Camshaft ?
KJHOOVER62
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10650 |
303-762-0022 Those aren't the specs, but if you call that number they should be able to tell you whatever you want to know. And it'll be straight from the Cam Research people It'll be easier, quicker and the info will be accurate Then you could post whatever info you get right here. |
gun-driver
gun-driver
That was written incorrectly as you can see he scratched out the LH😂
Thanks(1)
I guess he forgot to scratch out the firing order
