Points problem |
Post Reply | Page <12 |
Author | ||
Kristof
Grand Poobah Joined: October-08-2007 Location: Bree, Belgium Status: Offline Points: 3387 |
MrMcD
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3582 |
You guys are pretty funny.
Points problem history, when I installed my first set back in 1974 I failed to lubricate the lobes. All points used to come with a little container with point lobe lube. I failed to lubricate and the car left me stranded a couple days later. On tear down the points were closed, lack of lube on the new points allowed them to wear until the points closed. A little lube on the lobes is mandatory if you want them to live. I also installed a set of points because my old points had fried. When I bought new points I failed to buy a new condensor. Guess what, a couple days later I was stranded again, points were glazed over and not working. A little file work and a new condensor and they were happy again. Check your voltage to the distributor while cranking and while running. Cranking you should have 12V, after it starts that will drop down, I think 7.8 to 8.5 V. The lower voltage as mentioned above in a post increases the life of your points. Full battery voltage on start up helps you fire up faster. It would help diagnose to know what you see when you take out the old set of points. Is the gap closed? Are the points frosted over? You have a problem that needs to be fixed. The engine will run well with points once fixed. For simplicity I switched a couple engines over to the GM HEI distributor, they make a conversion for the Ford engine. These work very well, start quickly and eliminate points. If you ever have an issue the HEI parts are available at all auto parts stores. I liked the improvement in cold start with the HEI installed. The distributor and plug wires need to be changed if you go with HEI. You need later model high energy plug wires. Edit: the HEI may not meet coast guard requirements for spark control, you don't want to blow up your boat. Hope you get it fixed. Mark |
phatsat67
PCM didn't wire with a 12v shot during cranking. I have tested both ways and saw no difference. If you are getting low voltage from the get go then that may help start up but really does nothing on a healthy points system. |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10606 |
Paul You're all screwed up, that's Pete flogging me with a 28 year old dead fish That's how long he really went without looking at his points according to this old thread link Here's a quote from the thread in the link, fairly entertaining thread if you read the whole thing
gt40KS
Maybe it's just me, but I'm still kinda stuck on how it is that Pete knows so much about acrylic nails and emery boards ....
JCCI
1995 Ski Nautique GT40 |
MrMcD
Heck, I want to know how many hours are involved in the 28 years.
It may be 28 years and a total of 30 minutes run time! Sorry Pete, the photo had me ready to jump in. Mark |
Smithfamily
Platinum Member Joined: December-26-2007 Location: Orlando, Fl Status: Offline Points: 1602 |
Emery board grits: "80 grit β sharp and very rough, used for removing outer gel or acrylic overlays. Itβs too rough for natural nails. 180 grit β medium sharp and medium rough, used for preparing nail plate before applying gel or acryl and for shaping artificial nails. 240 grit β not so sharp and rough, for final filing artificial nails. This grit can be used for filing natural nails." All too coarse of a grit in my opinion. You what to remove the oxide that forms on the contact faces and not the Silver Cadmium plating. It's rumored that with the manufacturing done in China that the plating isn't what it used to be! [/QUOTE] I think we are all missing the POINT here? How has Pete become an expert on emery boards?? Is he hanging out in that Vietnamese nail salon near the Home Depot?? Hahaha |
Js
You could go to the link a few posts back and read thru it or you could click on this link below. It's in there on the second page link |
MrMcD
Dang Ken, that post was 3 years before I joined this site.
Pete Nice work getting 600 hours out of your set of points. Myself I never had that kind of luck or talent. We always found a way to forget the key was in the Run Position while the engine was not actually running and fried the points. Usually it was a kid that wanted to hear the stereo. I finally wired the stereo live to avoid needing the key on. |
