Steering Wheel Off Center |
Cam05210
Groupie Joined: July-27-2009 Location: Charlotte Status: Offline Points: 40 |
Posted: August-17-2019 at 1:30pm |
The former owner put a 4blade prop on my '89 2001 and the steering wheel is a 1/4 turn off center. Is this fixable by simply removing the prop, straightening the wheel and re-installing??
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21108 |
Prop won’t affect the wheel... to clock, you’ll need to pull the cable out of the helm, adjust the wheel and reinsert.
Cam05210
Hmmm...yeah, I guess now that I read that back,..pulling the prop would do anything at all...lol......is this an extensive project??
Netdewt
Senior Member Joined: February-15-2010 Location: Minneapolis Status: Offline Points: 215 |
My steering wheel is off center, and it also has a decent amount of loose play from side to side. Is that fixable?
1989 Ski Nautique 2001, 880 hours
Nate,
Where is the play? In the helm or at the tiller arm to rudder post? |
Netdewt
In the wheel at the helm. Rudder seems to stay put.
Do a search here on CCF for "steering wheel centering", There's a fair amount written about how to do it.
As far as the slop goes, have you lifted the center floorboard behind the engine and looked at the steering tube clamp block both where it hooks to the tube and the ball and socket that the clamp pivots on? Also look at where the clamp mounts to the boat itself to be sure that's tight. Slop in those places will let the cable move without the rudder moving Check the ball joint where the cable hooks to the tiller arm for slop/looseness too If you get or have all that tight, then move on to centering the wheel. See what TRB said early in this thread |
MourningWood
Gold Member Joined: June-13-2014 Location: NorCal Status: Offline Points: 885 |
yes, at the 'tiller end of the steering cable.....the 2 pieces (with 4 bolts) that form the pivot 'socket' are simple castings that wear fairly quickly without grease.
1994 Ski Nautique "Riot"
